07-11-2007, 01:54 PM
My Ride: 1999 Integra GSR
Engine: 1.8 DOHC VTEC
Id bet its the turbo, is it a constant stream of smoke, does it smoke ALOT when you start driving and then thin out when you coast? If that is the case, a rebuild kit is just the minimum take the turbo apart, make sure the shaft hasnt been worn down and same with the center cartridge, if they have they will have to be machined and you will have to get oversized bearings, thats is if the turbo is salvagable in the first place.
