12-18-2007, 02:43 PM
Re: Which Fuel Pump for Shadow 2.5 Turbo?
My Ride: 88S.Tona,87+88Shadow
Engine: 2.2TI,2.2TII,2.5TII
There is both a 190 and a 255 made for our cars.
It is usually listed as 80's FWD mopar if your are looking through a parts store ect.
Made by Walbro, Holley, and an Edelbrock unit. I believe all all the same pump, but labeled under different names.
FWDperformance.com
Checkout these sites, they will have what you are looking for.
As for overkill, having the ability to supply more fuel is alot better then the chance of going lean IMO. Fuel pump is easier to replace then a piston(detonation). 14-15psi is the upper limit of what should be run on stock fuel system(Intercooled of course)
I believe the 190 can be ran at stock fuel pressure without running rich, not sure on the 255.
Hope this helps.
