Old 02-04-2008, 09:51 AM   #16
Re: Any suggestions: Twin turbo 350
MEOW!
My Ride: 87shelby charger
Engine: 2.2L TII
Images: 152
Originally Posted by turbomini View Post
well not to make every one on here made but my brother just bought a twine turbo set up for a SBC and it was only like 400 with turbo's that push 14psi... lol i''l be back
ok i'm back... this came with headers and everything to turbo a 80's camaro with tune port...
turbomini is offline
Old 02-04-2008, 10:07 PM   #17
My Ride: 1985 shelby charger
What turbo kit is this? 400 bucks and it comes with headers and turbos?
1984Rampage is offline
Old 02-04-2008, 10:25 PM   #18
My Ride: 92 Shadow
Engine: 2.5 T1
SBC in a ford is just stupid and way overdone. Ford in a ford, chevy in a chevy, mopar in a mopar.
bhazard is offline
Old 02-04-2008, 10:38 PM   #19
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
there are plenty of factory fuel injected 350s, find one of them at a junk yard... you can do a blow through carb too, i don't know what it would take to do one, but it is common enough.
kermit is offline
Old 02-05-2008, 09:15 AM   #20
My Ride: '90 dodge caravan
Engine: 2.5L
ok, I had been meaning to rig this up on my old pickup, and if you want to do it with a 350, then here's some pointers/ideas that I had. I haven't done all of it because... 12mpg is bad enough and I can't really justify the addition of turbos. I just put fuel injection in it and a .440/.454 lift cam and this old 4x4 will hit 50 before you know whats goin on.
- get an older sbc. in the 70's to... 82 or 83ish they ran 8.2:1 compression, and then in about 85+ they ran with swirl heads at 8.5:1 compression. the swirls flowed a hair better than the 70's ones, but were very prone to detonation according to a performance shop I went to. one idea is get a 350 diesel and swap the heads for gasoline use, this was a common modification at dealers because the 350 diesel sucked giant hairy monkey nuts. you'll have the stronger bottom end, but I don't know if you'd have to swap pistons. The biggest problem with the 70's heads is the middle two bolts going to the intake manifold are at difrent angles depending on the years. Thankfully the fuel injection manifolds are aluminum and God invented dremels.
- install a high flow oil pump. they really ARE high flow oil pumps, not just ones that SAY high flow. you can physically compare them. my 1978 pickup's oil pressure is about 45psi at IDLE. 75psi allllll dayyyyyy lonnnnnng.
- ram's horn manifolds. you'll recognize them if you see them, they're very squat. you simply flip them upside down (yeah they'll still bolt up just fine) and rig some kind of adapter from the exhaust of the manifold to the turbo. a nice chunk of plate steel should do. this should be easier, cheaper, and stronger than building custom headers.
- fuel injection. my fuel injection came from a 1990 gmc van. the ecu in a van is under the driver's seat btw. just rip the entire intake system and the spark timing mechanism. don't forget the knock sensor thats down on the right side of the block. it goes into a drain hole for the water jacket so sbc's already have that hole tapped. I have a 78 model for crying out loud. My ecu is laying on a rag on the left wheel well and is none the worse for wear. The stock fuel circuit uses the oil pressure sensor as a switch for the fuel pump, and without that oil pressure sensor the fuel system will cut out after a bit. I use a switch on the dash. Rigging the hookup for the turbo to the tbi may be difficult however, and keep in mind that the stock fuel pressure was a mere 14psi. you'll have to figure out some kind of rising rate regulator. The stock regulator is adjustable with a philips screwdriver (do a search on google for how) but I don't know if it will raise fuel pressure to compensate for boost like ours will. Oh, and don't forget the fuel pump.
- oil lines T'd off of the oil pressure sensor line in the back (behind the dist) and and T the coolant off the heater lines. you want the turbos to be below the level of the radiator so when they sit there and boil the coolant off, the steam can go into the radiator and not just sit there. the return lines for the oil can go into the oil pan. I was planning on using twin mitsu's and putting a cone air filter on the intake of each turbo. have them sticking up there like horns. Maybe a flap in the hood (vaccuum operated or manual, I hadn't really decided. be neat to be able to do it in car in case it started raining) to open up the intakes on some bullnose hood scoops to feed those turbos.
Hope this helps. Most of that is probably useful no matter what engine you use. I just felt that since the engine probably couldn't survive 13psi (its almost 30yrs old), and my K engine did that stock it just felt useless to go to all that trouble if you're not going to be able to run good boost.
genghis05 is offline
Old 02-05-2008, 09:55 AM   #21
My Ride: 92 Shadow
Engine: 2.5 T1
Ive heard of people converting the diesel 350's to gas cause the diesel bottom end is so much tougher than the gas engine. Sounds logical.
bhazard is offline
Old 02-05-2008, 10:40 AM   #22
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
theres a guy in town here who rat rodded a 5.0 mustang with S-60 size twins and he runs low 11s on pump gas consistently.... but, hes a geniouse. its ugly as crap under the hood, but holy crap!! it goes!!!!!
turbo minivan is online now
Old 02-05-2008, 10:47 AM   #23
Originally Posted by impuresoul2k3 View Post
You are going to have to modify a carb for blow through boost, or buy a carb already made for it. Otherwise I think it will pressurize the carb and you'll get no fuel
yes, if you do a blow through, youll have to build a pressure box for the carb, if you do a draw through, youll have to have a turbo wigth propper seals that are able to handle the fuel passing the blades and not getting into the bearing, otherwise itll burn up real quick. i have 2 go-karts with turbos and they are both blow throughs and work great. you could also do a blow through if you had a RRR type fuel pump to keep pumping fuel over the boost pressure wile under boost. i think its more work than your thinking. even turboing my go-karts wasnt as simple as it sounds.
Old 02-05-2008, 03:07 PM   #24
I know its not gonna be easy but I just want to try it. So would the alcohol injection work if I converted my carburater to blow through and then as soon as boost hits I have the alky come on? Or am I just crazy? Also Ive been reading turbomustangs and it recomends a book called maximum boost. Is it worth getting?
Credit Report | Bankruptcy Certification | Free Ringtone | Reptile Store | Actress
Page generated in 0.37672 seconds with 13 queries
