02-25-2008, 10:07 PM
Re: 5.9 Magnum log manifold tube size??
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
I'd measure the perimeter of the inside of the flange and select a tube size that will match it. With a turbo manifold, you just want maximum flow and heat retention. Twin Garrett's may be a little small for a 5.9. I've got two of them on my 2.5... The T3 flange is also not the right bolt pattern for a Chrysler turbo, but gives you many more turbo options. People have drilled Chrysler flanges for the T3 pattern and had the option of using either style turbo.
Sounds like a fun project, always wanted to TT a V8.
