Old 04-12-2008, 05:01 PM   #1
still have a no -start - pulling codes 11,12,14,??
no idea i think its the hall effect plate because im getting a code for no ignition reference, and map sensor voltage too high/low so should i replace map sensor then hall effect ? if the pickup is bad does it not let the computer see a crank position causing no-start when i pull the plugs i get spark ????? im stumped , i got fuel on the plugs too ? i replaced coil,plugs ,cap/rotor - the next thing is the hall effect pickup ? and map sensor .
paulmi is offline
Old 04-13-2008, 09:25 AM   #2
Re: still have a no -start - pulling codes 11,12,14,??
i have power to red asd relay wire at connector , jumpered asd relay terminals and have power from -side of batt to + side of coil, injector harness dg/bk wire has 12 v only when key is in on position and asd connector is jumpered , + side battery to + side of coil has 12 v , ??????
funny after i take off jumper from asd connector the fan and relay start kicking on /off for 20 seconds or so and one of the solenoids on the passerger fender is clicking after the fan shuts off thi is with no asd relay and no jumper wire in its place with key in on position ????? im thinking the compyter is doing some freaky things ??????? pulling codes 11, still but 14 went away ??? no ignition reference signal ??? hep bad or is computer fooling me into thinking its bad ??????? please help >?
paulmi is offline
Loans | 50 Cent MP3 Download | Loans | Secured Loans | The eBay Song
1320drag - Drag Racing resource Nissan 240 Forum Audi Forum My Chemical Romance Forum BonneVille Forum Chevrole Forum Camaro Forum Car Audio Forum Car Video Forum Canadian Mutsang Forum Dodge Intrepid Forum Emma Watson Fan Site GM Forum Tuner news GT cars Honda Forum Jeep Forum Mazda Miata Forum RC Forum Mustang Forum Dodge Forum Zero Hurtz
Page generated in 0.25717 seconds with 13 queries
