01-09-2009, 10:04 AM
#27
Re: turbo 440 rv
My Ride: 69 D200
This looks very close to mine. Diff. make/company but same layout. I,m ,still looking at how to set it up as I'm new to turbocharging.I did pick up a clean 87 shelby charger 12yrs or so a go with a blow up 2.2 an dropped a junk yard engine just to turn some bucks. After getting it up and running,didn't catch that the w/gate was not hooked up. On the "test ride" I was to say the least,shocked at how it pulled through 1st an 2nd till the over boost shut down the fuel. knew then, thats what a 440 needed. mine has a 301 rajay turbo mounted on a t4 flange. by what I,ve been reading it might be choking it up in the rpm's? and thinking of finding a 2nd set up for mine,skip and block off the the cross over and run twins. want to just get it bolted on for now an see what I got, then go from there. Any in put on this idea any body? looks like my turbo mounts a little more on top of the ex.manifold vers out the side. the one in your pics looks like it would clear the floor and engine cover on my 1966 "Dodge Moter Home" (travco) which is what I org. planed to put mine on.
