11-23-2008, 04:17 AM
Re: Why I needed 4 TE04h's
NORCAL
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
i already knew what you were up too...on you sig. it says your ride is an exploder
wish ya luck though...
keep us updated, id like to see how they run
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
