How do i identify the vnt? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > VNT & Other Turbo Vehicles
VNT & Other Turbo Vehicles Help for VNT cars & other turbocharged vehicle technical section.
Old 11-14-2012, 06:10 PM   #1
My Ride: 1993 Shadow ES
littleweasel is keeping the peace
I have a friend who bought an 89 CSX. Thing is, this happens to have the Maserati 16v head from a Chrysler TC bolted atop the 2.2 mill. According to him (I've yet to view the car), a Garrett turbo is bolted up to the motor. What are some tell tale signs that the turbo is a VNT?
Thanks much
littleweasel is offline
Old 11-14-2012, 07:00 PM   #2
Re: How do i identify the vnt?
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
GLHNSLHT2 has really helped outGLHNSLHT2 has really helped out
pics please!!!
To put a VNT on a Masi 16v you'd have to have a flange welded to the exhaust manny as the bolt pattern is way different. The factory masi IHI turbo is very tiny, the VNT isn't much bigger. Either turbo is choking that motor off seriously.
GLHNSLHT2 is offline
Old 11-14-2012, 07:33 PM   #3
I plan to look at it Saturday. He says the turbo is a Garrett. If it is VNT, which CSXs came stock with, could it be possible that the guy my buddy bought it from just slapped a Maser head on a turbo IV?
Old 11-14-2012, 07:57 PM   #4
NAJ's Avatar
Feedback: (21)
The T-4 block is the same as the T-2 other than the balance shaft used in the T-4.
The VNT does not use a wastegate, it has 4 vacuum lines, 2 to the actuator and 2 to the compressor housing as opposed to the 2 on the Garrett, wastegate and compressor housing.
The VNT uses 3 VNT Solenoids as opposed to one wastegate solenoid on the T-2 Garrett.
VNT is an engine code "C"(8th digit)
VNT SOLENOIDS,solenoid 1 is mounted on the strut tower, then VNT solenoids 2/3 and then the purge solenoid.(on fender, top to bottom)
Jan
1990 Daytona Shelby VNT
34 Years ASE Certified
Old 11-14-2012, 08:42 PM   #5
Legendary Driver
GLHNSLHT2's Avatar
Possibly, or he could of used the whole Masi engine and put the VNT on it. Because the crank, rods and pistons are much different than a T2 or T4. To mount the VNT there'd have to be a Chryco flange welded to the Masi exhaust manifold. Heck to mount any turbo other than stock requires a new flange as the bolt pattern is somewhat unique to the masi. A VNT will have a very sharp elbow on the exhaust side of the turbo for the O2. It's actuator for the vanes is in the middle of the turbo and the rod goes up and down instead of across the turbo.
Old 11-15-2012, 09:04 AM   #6
Well, i spoke with my buddy this morning. It's got a wastegate on it, so no VNT. What's the hottest hybrid setup that could be made from the 2.2/2.5 turbo motors, anyway?
Old 11-15-2012, 06:22 PM   #7
Legendary Driver
GLHNSLHT2's Avatar
IMO the Masi is pretty much it, Flows as well as any of the rest of the heads out there. but has Cam on bucket top end, so much less rotating weight and the weight of the head makes a Lotus feel like it's made from cast iron. Something like a 33lb difference between those two heads.
The neon is ok on a 2.2/2.5 but it's much better, easier and cheaper to just go whole 2.4 in the case of using that head.
Old 11-17-2012, 08:54 PM   #8
Fox
My Ride: 89 shelby csx
Engine: 2.2 Turbo IV
Fox is keeping the peace
post some pics of the car if you can
Fox is offline
Old 11-27-2012, 09:29 AM   #9
My buddy had the masi head blueprinted. If only for novelty's sake, would anyone be interested in a reproduction 16 valve direct 2.2/2.5 bolt on?
Old 11-27-2012, 07:06 PM   #10
My Ride: 87 SHELBY CSX
Engine: 2.2 Turbo II
azkcar135 is keeping the peace
Pics please!!!!!
azkcar135 is offline
Old 11-27-2012, 09:41 PM   #11
Super Pope
The Pope's Avatar
Feedback: (10)
sure I'll trade you the stock VNT top end for it
The Pope is offline
