06-15-2004, 10:24 PM
#18
My Ride: 1987 Shelby Z
Engine: 2.2L Turbo II
There isn't much difference body wise between the 90/91's and the 92's as far as I know. And the ecu is very similar to the one that is in there already, so it should mout right up, hell, they may even use the same wiring harness.
06-16-2004, 12:10 AM
#20
jesus, that thing is huge......it might fit with some huge modification.
06-27-2004, 05:03 PM
#22
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Great car, i'd love to have a body kit like that.
-Steve Reject.
1992 Chrysler Lebaron GTC 3.0L 175,000 miles
Engine K&N Cold Air Intake, 52mm Throttle Body, Intake Plenum Spacers, 2.25" catback, MSD Coil,Accel 8mm wires, NGK V-Power Plugs, Trans Cooler, Aluminum Radiator
Suspension A-Spec Strut Tower Bar, Falken ZE-502 205/55/16, Bilstein SportTouring Struts, KYB Gasajust shocks, Boxed in Panhard Bar, Poly Sway Bushings, Polyurethane motor mounts,
06-28-2004, 09:20 AM
#24
Engine: 3.0L V-6
Red lights would be a bad idea IMO, it WILL cost you later.
-Steve Reject.
07-07-2004, 09:24 AM
#26
My Ride: 92 GTC, S2000, GTP
[quote=YoungGun05]hey i was looking at intercoolers and was wondering if this one would fit my car. http://cgi.ebay.com/ebaymotors/ws/eB...904966019&rd=1
And if that does fit then what else do I need.
Damn, unless you are doing fuel mods and plenty of other things, I would go with a bolt in VNT or R/T Intercooler/rad combo. I just did that for $225 and my rad is new (recored) and the IC is new. I'm pleased and just need a coolant overflow bottle now. Pics to come.
07-07-2004, 10:18 AM
#28
1/4: 13.650
Why not just convert to a 90/91' ECU and wiring harness, they are pretty common from what I have seen, if you can't find one, I'll get you one for a good deal, I think I know where half a dozen are. How different are the ECU and Wiring harnesses between the 90/91's and 92+.
Ummm they are WAYYYY different. The 92 T-1 computer is the SBEC II configuration ( http://hhscott.com/93tmv/SBEC_Conn.htm)
The general consensis is that to get a cal, you will have to either re wire the entire car with a 90 harness, or attemp the dual SBEC config outlined in the above website. As for getting someone to re cal a sbec II, the T-1 sbec II is RARE......and cores would be a problem.
Anyway, REALLY nice car. I would tacle the wiring job on a nice car like that.......That is a A&A body kit. The Razzi one had the ugly ribs in it on the side skirts. And as mentioned before, the grill being blocked off will hurt flow, so i would go back to the original configuration. Check out my website for what i did to my grill (like the blue baron's grille)
Lastly, that cooler is NOT going to fit in the car.....take it from experience. If you are going to keep it somewhat stock, the spirit R/T intercooler radiator will be good. I just got done stuffing a Spearco 221 intercooler in the front, and kept my flip lights in tact. It was a squeeze.
Good luck
Joe
07-17-2004, 12:09 PM
#30
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
I too have a 92 gtc 5spd convertible. ( still in my garage since August) brrn busy...
I understand to convert to 91 electronics you have to add 1 cable for the air charge sensor, drill a hole for the sensor and move a couple pins on the computer harness. As far as the intercooler goes, I plan on puting a second headlight door motor instead of having one in the middle, the car will have 2 motors right next to the headlight doors.
