Old 08-24-2005, 12:52 PM   #1
twin turbo 383 mopar are t3's sufficient?
I am throwing around the idea of doing twin turbos on my 383 big block. will standard t3's be large enough? I plan on intercooling it also.
89CSX#17 is offline
Old 08-24-2005, 01:41 PM   #2
My Ride: Daytona Tubo Z C/S
Engine: 2.2 Turbo
Just depends on what kind of power output you want & at what range of RPM. Lots of people put the .60/.63 housing turbos on everything from 302s to 460s. Knew a guy who had 'em on a 460 Ford, made almost a thousand ft. lbs. of torque, but only around 350 hp & it ran out of breathe around 4500 rpm. Minimum I'd say is a pair off a Grand National or step up to a pair of HX 35 or HX 40 Holsets off of Cummins diesels which would be damn near ideal.
I've got a 64 Galaxie that'll eventually have twins on it, I plan on using the Holset pieces unless I can find a mate to this TE06H that I've got sitting here.
Good luck!
JeremyL is offline
Old 08-24-2005, 03:28 PM   #3
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
I have an hy35w which is slightly smaller on the exhaust side than a HX35w. I think that is too big for a twin V8 setup, you'd probably spool both of them by like 4K RPM
Garret is offline
Mortgage Calculator | Strokes | Mortgages | Car Loans | Mortgages
Page generated in 0.28354 seconds with 13 queries
