Old 09-28-2005, 08:38 PM   #1
2.2 carb to 2.5 carb ????
just wondering if i can replace my 2.2 short block with a 2.5 tbi short block ??
2fst4u is offline
Old 09-28-2005, 10:00 PM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Heck yeah.. Just make sure you put a swirl port head on the TBI block, or your compression will be low and power will suck.
Una is offline
Old 09-29-2005, 08:39 AM   #3
yes you can... the compression ratios between a TBI 2.5 and a TBI 2.2 or 2.2 carb non HO or non Shelby are nearly the same. the 2.5 is 8.9:1 and a 2.2 is 9.0:1, your carb intake will bolt right on, you'll need to change some sensors to plug into the cars wire harness, but this is a bolt in swap. I would suggest ditching the feedback carb and go with a Weber DGV... or even get a caravan or dakota carb, they are non-feedback.
allmotor is offline
Old 09-29-2005, 02:40 PM   #4
i noticed you said the 2.2 had more compression does that mean i could make more power with a carbed 2.2 or 2.5 ???
2fst4u is offline
Old 09-29-2005, 04:04 PM   #5
i guess you didn't see that the 2.2 is 9:1 and a 2.5 is 8.9:1 so that is so insignificant.
allmotor is offline
Old 09-29-2005, 04:48 PM   #6
Una
Engine: 2.5L Turbo
Yeah, a .1 difference is jack.. You can get that from surfacing the head a hair too much.
Una is offline
Old 09-29-2005, 04:53 PM   #7
the biggest advantage will be the increase in torque.
allmotor is offline
Old 09-29-2005, 05:16 PM   #8
so should i stay with the 2.2 or the 2.5 ?? remember the car has to have a auto trans in it
2fst4u is offline
Old 09-29-2005, 07:06 PM   #9
Well depending on what you want to do you could mix and match some parts. For instance the 87 and 88 2.5's can use 2.2 pistons. You could use some of the Carb flat tops in it, or mill the block .043" and use early T1 pistons with a G-head. Your cr would be 9.83 to 1. You might want to see what you want to do with the gearing of the trans. You might want to look into taking control of the timing also.
Daniel Merrill
<---- PLEASE Provide feedback for posts you like!
89acclaim is offline
Old 09-30-2005, 08:50 AM   #10
86-88 2.5 has the EXACT same pin height as the 2.2 so if you use a 2.5 from this era you can easily increase the compression to 11:1... however these engines are approximiately 5/8" taller block so hood clearance my come into play on the carburator. If you use a 2.5 common block, the deck height is exactly the same as all previous 2.2 engines but a flat top piston conversion is a bit more involved (cost or machining) if you have access to a 2.5 cheap, I'd use it in your car, it won't hurt what so ever and you will notice the extra 20 or so ft lbs of torque even though the only difference in hp is just a couple... the torque is very noticeable in a positive perspective.
allmotor is offline
Loans | Bad Credit Mortgages | Loans | Mobile Phones | Loans
Page generated in 0.39484 seconds with 13 queries
