Old 10-03-2005, 12:24 AM   #1
carb block
what year blocks can i use to rebuild as a carb block ?? must have fuel pump block off plate so i can use a manual pump
2fst4u is offline
Old 10-03-2005, 01:15 AM   #2
My Ride: 87 Dodge Omni
Engine: I4 2.2l
If you want to use the mechanical pump, then I believe any block up to and including 1988. You'd just need to remove the block off plate on the turbo and TBI block and install the pump You could use a 89 up common block, but you'd need to run an electric pump.
you're building yourself a circle track racer, right?? try finding a 2.5 tallblock, and run a long rod 2.2. check this link out, may be of interest to you.
Long Rod 2.2
Cooter is offline
Old 10-03-2005, 02:05 AM   #3
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Ack.. Never read that longrod article before.. Sounds like a PITA.. Custom rods, custom pistons.. Bleh.. Sure would be nice with a hybrid head tho..
Una is offline
Old 10-03-2005, 03:41 AM   #4
Engine: I4 2.2l
that article is just a guideline....from a PM from 22dodge, here's his take on the situation
"Some CHEAP performance mods I have done for a 2.2 was to use turbo pistons, mill them to a flat top and use 1986 2.5 rods. this rods measure 6.125" vs 5.94 for the 2.2. the longer rod increased torque on my circle track engine by creating a higher dwell for the piston at TDC."
He did it using a 2.2 block, I shoulda posted this before that article....
Cooter is offline
Old 10-03-2005, 03:37 PM   #5
You could do a long rod 2.2 with the 87/88 2.5 rods and 89+ 2.5 TBI pistons. Though if you didn't mill any the compression would be about 8to1. Though the 2.5 tallblock carb would be a nice engine.
Daniel Merrill
89acclaim is offline
Myspace Glitter Graphics | Credit Cards UK | Internet Advertising | Property for sale in Spain | Bad Credit Loan
Page generated in 0.34613 seconds with 13 queries
