Old 10-06-2005, 03:46 PM   #1
turbo block for n/a motor rebuild ??
can i use a turbo block for my n/a motor build up ?? i know the pistons need to be changed but what else ??
2fst4u is offline
Old 10-06-2005, 07:26 PM   #2
block off the oil return for the turbo, raise the compression, and put a (roller) n/a camshaft in! for the compression, maybe just shave the block or the head to bring it up to n/a specs, that way you keep the heavy duty pistons and save the trouble getting the correct year/engine size pistons for your build up.
capev86 is offline
Old 10-06-2005, 07:27 PM   #3
a lot of turbo spec parts are great for n/a buildups like the compression rings!
capev86 is offline
Old 10-06-2005, 08:11 PM   #4
make sure u use a swirl head to raise the compression
BuRn__ is offline
Old 10-06-2005, 10:05 PM   #5
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
my father had a K-car with a turbo block that was from a GLH that the made into an N/A because it was what was available. I drove my laser without a turbo for 6 months. a turbo Block in a N/A car is fine if you block off the turbo lines or cap them to the pan and block and make the other approriate changes. my father worked on car 25 yrs, i beleive that he wouldnt do the swap into if he knew it wouldnt have worked right. that car ran forever and was sold running.
xtrempickup is offline
Manga | Glitter Graphics | Remortgages | Adverse Credit Remortgage | Loans
Page generated in 0.32947 seconds with 13 queries
