11-11-2005, 01:07 AM
update:
I got some limited wiring diagrams from a 92 shadow turbo, most everything is similar..
Jumped a wire to the pump. pump works fine.
No power at pump +wire.(DK Grn -WHT tracer)
Inputs to ASD and Fuel pump relays are good, I have spark and it turns over, runs on starter fluid.
OUTPUTS of Fuelpump relay are good.. I get my 12v for 2 seconds as it should when priming...
So, the fuelpump relay is working fine but there has to be a break or a bad connections someplace from the relay to the pump.. Does anyone know of any if the fuel pump +wire goes through any fuses or splices anywhere in the chassis or at the firewall connection? I am trying to avoid cutting all the tape, zipties, and taking apart the dash to trace the wire if possible... Again, my wiring diagrams don't show that it(+wire to pump) does. I gotta get this thing going VERY SOON..
