11-23-2005, 08:47 PM
Stupid 3.0 heater hose question...
Does the heater core "supply" hose go to on the top of the heater core or the bottom? This is a standard Temp controlled car, with A/C, if it matters.
91 3.0 5spd Daytona
Currently, my heater core HOT supply hose goes to the TOP of the heater core. with the lower heater core outlet being a bit cooler, and thereby the return hose. Wouldn't it make more sense to put the supply on the bottom, so any sediment(junk) that settled, would not be able to collect and clog the heater core?
Yep, my heater core is partially clogged, and it's getting pretty damn cold out. I looked at the Factory Service manual, and it is not clear on how they are to be hooked up (one crappy photo for the Auto-temp system). On the 3.0 coolant flow diagram, they show the heater core as left/right setup, and not an up/down setup.
Anyhow, I'm going to switch the hoses tonight and see if it helps. I'm just curious which way they are "SUPPOSED" to be connected to begin with.
Thanks!
Mike (440trk)
