12-02-2005, 09:14 PM
#16
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Yup.. Now if the Omni is '88 or '89, try to find an '88 or '89 van, as you won't have to relocate any pins if the car and the harness is the same year. It's only 2 pins to move to put an '89 harness into an '88 Omni tho..So it's not life or death,but if you have a choice...
The harness is really the easiest part.The hard part will be shoehorning that beast into the Omni. Why not stuff in a 3.8L?  Now THAT would be cool.
12-02-2005, 09:47 PM
#17
ANTI BOWTIE.
My Ride: 04 2500 cummins
Engine: 5.9 I6
Cause the 3.0 has a 5sp trans for it and the 3.3 3.8 only has the junk ruber band drive.
________________________________
Jon Clements
MostOutrageousPowerAndRev!!!!!!!!!!!!!!!!
04 dodge 2500 qad cab short box cummins 6sp 6" lift quadzilla X2. My DD.
03 VW beetle TDI 5sp G/F's DD
07 honda crf 450x. SOON to be Street legal and my DD
82 dodge short box step side 2wd, mild 318 with shift kit. NICE truck for sale
78 dodge power wagon short box step side 400 BB 4sp 4x4.
Mopar or No car!!
12-02-2005, 10:07 PM
#18
Engine: 2.5L Turbo
Ahhh yeah, good point..
12-03-2005, 07:22 PM
#20
Engine: 2.5L Turbo
Grab the '88 engine harness (plugs into the injectors, alternator, sensors, etc), just to be sure you have no problem plugging the engine into the car. I had to change the engine harness when I put the '87 engine into the '95 van..
12-03-2005, 09:19 PM
#22
Engine: 2.5L Turbo
Broaden your search, automatics were very common in Omni's and Horizon's in '88-'89.. Converting it to 5 speed is no big deal, especially since you'll have to convert to cable shift anyways.
12-03-2005, 10:58 PM
#23
you are going to need newer style shifter stuff.
Also, you will probably have some problems with the radiator and fan. The stock 3.0 fan is lower profile then the 4 cylinder fans. In an omni, im sure this problem will be worse.
12-04-2005, 10:17 AM
#25
ANTI BOWTIE.
Engine: 5.9 I6
Originally Posted by XxhorizonxX
i can use the shifter and cables from the sundance right? its a 91 with the 3.0 and 543. what would be best suggestion for radiator and fan then? i would like to REALLY find a 5 speed omni or horizon but i guess i could settle with an auto and convert it.
You should be able to use them cables shifter fine. I put a cable shited 525 in a 85 glht. I welded the shifter to the floor. It worked pretty good. And for a radiator just use the omni one. I am sure it would work fine. and use a newer lowprofile fan, if it will fit.
Jon Clements
Mopar or No car!!
12-04-2005, 10:19 AM
#26
ANTI BOWTIE.
Engine: 5.9 I6
Yup, only hard part is the pedals and on a omni its not hard anyhow.
Jon Clements
Mopar or No car!!
12-04-2005, 01:05 PM
#27
Engine: 2.5L Turbo
I'd get the engine/tranny bolted into the car, and then see how much space you have left for a radiator. Nothing like having to buy two because the first one didn't fit..
12-04-2005, 09:02 PM
#28
My Ride: 87 Shelby Lancer
Engine: 16v 2.2
what about axles? will his stock omni axles work in 3.0 trans?
12-05-2005, 12:06 AM
#29
I would go this route.
Ive always wanted to build a 3.0 omni. Now that I have a P body that wont be happening. I hope I get get the duster down somewhere near L body weight.
