Old 01-28-2006, 07:05 PM   #1
Turbo Caravan Questions
How fast are caravans in 1/4 with a 2.2. turbo? how much power and torque do they make? What are some modifications I can do to the exisiting engine to get more power. I dont want a 10sec van or anything but I want to whoop up on some hondas
krazyasslunatic is offline
Old 01-28-2006, 08:02 PM   #2
My Ride: need a TD
why don't you want the 2.5?
krazy4 is offline
Old 01-28-2006, 08:10 PM   #3
because it already has a 2.2 turbo
Old 01-28-2006, 08:22 PM   #4
did they come with a 2.2 turbo . . ? maybe it is a 2.5 turbo
Old 01-28-2006, 08:28 PM   #5
stock motor
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
The stock motor was a 2.5....The 2.2 NEVER came in a Mini Van
The turbo version came with 150 hp stock...
Best thing you can do is put on a 2.5 inch diameter exhaust and good muffler.
Then a K & N Air Filter, good spark plug wires, new tune up, and a perf computer. That will move it to the tune of some 15.50 range.
Bryan
Dave is offline
Old 01-28-2006, 08:39 PM   #6
My Ride: 87 Dodge Omni
Engine: I4 2.2l
the 2.2 did come in a caravan, 1984-1987 (1988?). but the turbo 2.2 never came in a caravan....only the 2.5 was turboed
Cooter is offline
Old 01-28-2006, 08:42 PM   #7
where can I get the computer and is it possible to upgrade the turbo?
Old 01-28-2006, 08:49 PM   #8
als
My Ride: 89 caravan es t1
Engine: 2.2 garett/ 3 inch e
someone installed a 2.2 inplace of the 2.5. more like dave said on times i run a 2.2 in mine with a 3 inch exth . has a fac. daytona intercooler it,s just fun to drive you get sum real looks . AL
als is offline
Old 01-28-2006, 08:57 PM   #9
okay heres a pic of the motor if that helps http://img394.imageshack.us/img394/5360/cimg01996wk.jpg
it already has:
-Powerstroke Diesel Intercooler
-1st gen DSM BOV
-recently rebuilt 85 "G-head" (stll have the original head, as well as the 89T1 cam and roller followers or whatever they're called
it says the boost is set at 10psi
So going off of those mods what should I do? I want like mid 14sec van
Old 01-28-2006, 08:59 PM   #10
My Ride: need a TD
get a 3 inch exhaust instead of a 2.5 inch, because you probably will upgrade that turbo later on
krazy4 is offline
Old 01-29-2006, 12:19 AM   #11
What turbo do you have?
If the mitsu, you will have to max the boost out of it. You will need to run either a custom cal from www.******************** or www.fwdperformance.com, 255 walbro pump, 3 inch exhaust, auto tranny mods per stickies in that section, slicks or drag radials.
Now, if you don't get a cal, you need to run +20's, AFPR and play with your fuel pressure until you get it right or run the stockers and cold starts.
To run low 14's, I ran a modded tranny, hi stall converter, 3 inch exhaust, stock garrett TIII turbo, small to medium intercooler, +20's, 255 pump, AFPR and 23ish psi. I managed 14.1@95 on street tires, but I got lucky.
Oh, and this was with a 2.5L and swirl head.
Old 01-29-2006, 12:24 AM   #12
Okay turbovanman i have no clue on half the stuff you said. I dont know much about turbos really. Right now I just want to get running dependably. He says its the stock turbo off an earlier t1 not a mitsu. Umm right now he says when the van starts pulling in the higher rpms the motor shuts off and for a little and then it will just come back on and start pulling again. Any clue what this could be?
Old 01-29-2006, 01:10 AM   #13
what do you mean by +20's and whats an afpr? what if I got the head ported and polished?. What if I gutted the van of everything but the essentials?
Old 01-29-2006, 01:29 AM   #14
Ok, you have a Garrett, which is good. If you hitting a cutout, your hitting the computers overboost cutout, which comes in around 14.7 psi to prevent you from destroying your engine.
The ported and polished head is good but unless the porter knows what he's doing, it will be a slight gain, our head suck ass. Gutting is good, less weight, faster van.
+20's is oversize injectors, they flow 20% more than stock. AFPR is an adjustable fuel pressure regulator.
Seriously, you should go to this site and read it a few hundred times, it will tell you how to eliminate the cut-out and other basics.
www.thedodgegarage.com and scroll to the turbo database section.
Old 01-29-2006, 01:47 AM   #15
Engine: I4 2.2l
Hey, if we only had some moderators in here, this could be moved to the correct place.....Instead of the N/A section.....
Cooter is offline
Credit Cards | Mortgages | Credit Card | Credit Cards | Free Verizon Ringtones
Page generated in 0.45173 seconds with 13 queries
