If you'd want to go carbed totally, maybe this: I've had this idea kicking around in my head that I'd like to use, and I don't know if it would work but I'd like to try. It would involve lots of custom work, but bragging rights to a killer naturally aspirated motor. If allmotor reads this he could tell you if it'd work or not.
Here goes.
1.) Chuck out the stock computer system. You won't need it. You can adapt old school VW distributors to work, go with an aftermarket mallory distributor, fully adjustable timing curve and electronic ignition and pickup.
2.) Go with a 16v DOHC conversion from a Stratus.
3.) Build yourself a custom intake manifold
4.) Set on the manifold two Weber 44 or 48 IDF carbrators. (the motor should handle it, aircooled VW's often use two of these suckers, together they'll flow over 1000cfm's!)
5.) Go with as high compression pistons as you can afford to run the gas, if it's strip only, you can go crazy.
Unless you're very hands on at machining this won't be too much of an option, as highering out all that labour would be expensive. A TII motor would be much cheaper and easier to get power from.
Another idea that I'm kicking around is a true dual exhuast. Have you ever heard how aircooled VW's sound? They have the most amazing sound a 4 cyclinder can produce! The sound is like two harley's side by side! It's the next best thing to a V8 in my opinion. Personally I hate rice burners exhausts, and the best of them still stand my hair on end.
To mimic the sound of the VW I'd like to make a header that would extract the exhuast gases in the exact same pattern. The VW fires first one bank, then the other, resulting in a pause in each exhaust pipe. (I can't remember the exact firing order, but I did figure out which way it worked.)
If I figured it correctly you would need to make make 2 headers, one connecting cylinders 1 and 4, the other 2 and 3. The exhaust gases would then exit identical to a VW's. Whether or not it would sound the same is another story, but I want to try it!
I hope I haven't wasted your time with my rambling, just throwing out some ideas for you to toy with!
