Old 04-16-2006, 06:50 PM   #1
Timing Help
My Ride: 84 Plymouth Turismo
Engine: 89 2.5 I/C TURBO
plz help
84 plymouth turismo ..carbed 35,000 , roller cam, 2.2 auto ...Hi all.......I am having a really bizzarr problem....checked the timing belt today
and all was on cue distrubutor out and and all marks aligned on bell housing and cam to intermediate shaft, crank..all good......BUT.. when I go to time the engine at 12 she bogs and has no power....so I tried 16 deg the same..the only way I can get her to go with no hesitation is to set her to past the 18 mark on the bell.Runs better and doesnt ping at all ......yes I have double checked all marks twice just to be sure....any ideas..running rich maybe...It is a carbed non feedback system and I pulled and plugged the hose at the scc..anyone got a hint?
Thanks
Robb
TurboTurismo is offline
Old 04-16-2006, 07:37 PM   #2
Blue Iroc R/T's Avatar
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
Originally Posted by Robb
plz help
Thanks
Robb
Did you align to the MARK on the intermediates shaft as shown in Fig. 11 or did you aligh to the elongated slot on the gear?
http://www.pbase.com/rmscott/image/35919219
You can also pull the distributor and see if the slot is parallel with the front of the block. That little mark on the gear face is sometimes very hard to see, but that is what needs to align with the mark on the crank.
Ralph
Blue Iroc R/T is offline
Old 04-16-2006, 08:42 PM   #3
The gear was paralell,,and rotor pointed to number 1..weird problem
Old 05-07-2006, 10:14 PM   #4
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Did you disconnect the vacuum hose to the computer? This reverts the timing back to base timing. If you don't, you will be trying to set computer adjusted timing back to base specs and it will be a total dog. Disconnect the hose & set base timing. It won't run very well at this point. Reconnect the hose and it will perk right up.
Mike
mpgmike is offline
Old 05-07-2006, 10:25 PM   #5
My Ride: 1987 caravan
Engine: 2.2 carb
Correct ingition timing is: warm up the engine then while running, pull both vacuum hose to SCC transductor can (plug the hose) and coolant sensor (for computer, 3 pin type). Then you can time it properly. When done shut down and reconnect both, unhook battery for few minutes.
Cheers, Wizard
Wizard is offline
Online Advertising | Mortgage Calculator | Mortgage | Yahoo Personals | Mortgages
Page generated in 0.76634 seconds with 13 queries
