Old 04-25-2006, 06:23 PM   #1
leaking from sparkplug?
the area around plug 3 of my omni glh is leaking, it is a minor leak.
What would cause this? I want to replace all the plugs and wires, what should I buy?
Oni Snake is offline
Old 04-25-2006, 09:10 PM   #2
My Ride: 1987 Dodge Omni
Engine: 2.2, later 2.5 turbo
by "area around" do you mean where the spark plug goes into the head?
By "leaking" do you mean oil?
You shouldn't be leaking any fluids from there at all. Check to make sure your spark plug isn't loose. Maybe it's leaking from the valve cover? or the head gasket (weird, but idk). Need info
Omnivore30psi is offline
Old 04-26-2006, 09:19 AM   #3
yes, it is leaking at the socket. Not horribly though. I was cleaning the engine w/ some degreaser and started it up after to listen and see if there were any noticable leaks, some from the valve cover, which means I need a new head gasket, and some from the 3rd cylindar's spark plug socket. It could be just air/gas escaping, perhaps it is not tight enough. I neglected to check at the time.
Old 04-26-2006, 09:39 AM   #4
Uh, leaks from valve cover = head gasket????? I don't get that one.
"the area around plug 3 of my omni glh is leaking, it is a minor leak"
what kind of leak????? compression, oil, coolant what the F are you talking about?
allmotor is offline
Old 04-26-2006, 10:02 AM   #5
I'm a novice here...the chrome valve cover on the GLH, is leaking around the gasket..whatever gasket that is, that is a valve cover isn't it?
There is an obvious leak of SOMETHING from the 3rd cylindar sparkplug socket w/ the sparkplug in there. There was some liquid sitting at the base and it was oscillating. It appeared to be going down into the socket, then coming back out. Not much, but enough that it is noticable to even me.
Liquid is brown, could be oil, could be degreaser and oil, etc. But it was moving, so at the very least there is air moving in and out at that spot.
Old 04-26-2006, 10:45 AM   #6
Clean the entire area again- clean enough that you would eat off of it. Then spray it down with some powder or cheap deodorant (the white kind, not clear). Start it up and watch for the leak.
I've seen and heard of cyl heads (especially on the old carb 2.2s) actually cracking around the spark plug recess. Hope that's not the case here!
-Chuck James
Stevien1 is offline
Old 04-26-2006, 10:53 AM   #7
-Chuck James
A shit, I hope not... Will give it another look tomorrow. It didn't look like anything was cracked on the outside.
Old 04-26-2006, 11:47 AM   #8
-Chuck James
Uh...I've been working on these engines since 1981, never ever have I seen the spark plug hole crack,,,,seen stripped and cross threaded, but never cracked. now if you were talking quad 4, them always crack from over tightening the plugs.
allmotor is offline
Old 04-26-2006, 11:53 AM   #9
allmotor, that makes me feel better.
I may have my mom's business sponsering the car a bit, that money would be going into an engine rebuild, or at the very least a good tune up, plugs, wires, gaskets, and the rest into the suspension mods.
Old 04-26-2006, 12:42 PM   #10
Why don't you just go out to your car with a plug socket and a ratchet and see if it's tight enough? Best case scenario the plug is loose. Worse case would be the threads in the head are stripped.
DaytonaTurbo87 is offline
Old 04-26-2006, 02:06 PM   #11
I didn't say the spark plug hole cracks, it's the recess above the actual spark plug. With the plug installed in the head, the area to watch out for is above the plug's insulator. I've had three 287 and 445 heads have that problem. Do a search on here and I'll bet you'll find other people that have had this problem too.
-Chuck James
Stevien1 is offline
Old 04-26-2006, 02:49 PM   #12
-Chuck James
must be a fluke... never seen that one, just did a search and no TSB's either, must be only turbo dodge board members with that problem... but then it seems to be a plague on here.
allmotor is offline
Payday Loans | Xecuter 3 Mod Chip | The eBay Song | Mortgage | Remortgages
Page generated in 0.69132 seconds with 13 queries
