Old 04-28-2006, 09:03 PM   #1
Failed Emmisions for the 3rd TIME!
Hey, i have a 92 duster 5speed, 4cyl
I have chanved the plugs, wires, cap and rotor etc.
Fuel filter, ran cleaner though the injector,
Changed cat converter, O2 sensor
AND IT STILL FAILS ON NOX
has anyone had this problem? Anyopne have any suggestions?
thanks!
brandon
spoolerr is offline
Old 05-07-2006, 10:07 PM   #2
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
1/2 bottle of isopropyl 70% rubbing alcohol. The combustion burns cooler and lowers NOx. You could also retard the cam timing upwards of 4-6 degrees which also lowers NOx.
Mike
mpgmike is offline
Old 05-07-2006, 10:20 PM   #3
My Ride: 1987 caravan
Engine: 2.2 carb
Did not check the EGR is working (test it with engine running if it's working and pull a vacuum on EGR diaphgram will make engine run rougher even stall) and did the coolant flush and new thermostat, radiator?
NOX is result of engine running too hot especially.
Cheers, Wizard
Wizard is offline
Credit Report | Loan | Mortgage Calculator | Loans | Loans
Page generated in 0.79300 seconds with 13 queries
