Old 06-18-2006, 02:51 AM   #1
Headgasket and bolt question
My Ride: 2003 SRT-4
Engine: 2.4L 4 cylinder
This weekend I picked up a 1985 Plymouth Horizon in need of a headgasket. No signs of cross-contamination in the oil, but its pushing pressure into the radiator. Unscrew the radiator cap and it puffs.
I remembered I have a set of headbolts and a headgasket for a 91 Daytona I never used. The headgasket is for a cross-drilled block and cylinder head. Im fairly certain the Horizon isnt cross-drilled. Can I safely get away with using a cross-drilled head-gasket on a non cross-drilled engine?
About the headbolts, the car was manufactured in Oct. 1984, this means it has 10mm headbolts instead of the 11mm headbolts on the 91 Daytona, correct?
brummy is offline
Old 06-18-2006, 06:44 AM   #2
pre 1986 engines have 10mm head bolts. the head gasket really doesn't matter. All I have in my inventory is cross drilled gaskets which I use on everything so that isn't a factor.
allmotor is offline
Old 06-18-2006, 09:18 AM   #3
My Ride: 2003 SRT-4
Thank you for the confirmation. Now I just need to get myself motivated to start tearing it apart.
brummy is offline
Old 06-18-2006, 09:50 AM   #4
and if you actually decide to do the work, don't use the 11mm head bolt torque specs. you'll break the head bolts.
allmotor is offline
Old 06-18-2006, 09:20 PM   #5
My Ride: 87 Shelby Lancer
Engine: 16v 2.2
I believe the change over was mid-85, my 85 gts had 11mm head bolts. It was turbo tho, they may have switched the turbo cars first. Only one way to find out for sure.
itoktoeatfish is offline
Old 06-19-2006, 05:07 AM   #6
It was actually a late 1985 model year change. (pretty rare but does exsist), but then we are also talking about 20+ year old cars, chances are even better that someone did an engine swap
allmotor is offline
W810i | Myspace Images | Loans | Loans | Free Advertising
Page generated in 0.88514 seconds with 13 queries
