Old 07-09-2006, 09:19 PM   #1
Circle Track Racing A 2.5 Need Help
My Ride: SPIRIT,VOYAGER,SRT4
Engine: 2.2/2.4
We will be running a 89 daytona 2.5 mpi at our local circle track and i would like to get some help from those who have run mopars. rules say we have to run f.i. if it came with it or carb if that is what it came with and factory electronics. what i want to do is use a 89 turbo mpi setup w/turbo electronics. because the rules don't say anything about changing the type of f.i. what do i need to do to do this swap and do the turbo electronics still have good maps when not in boost. what is a good factory exhaust manifold to use? thx in advance for any help
IRONMURT is offline
Old 07-09-2006, 09:52 PM   #2
Don't think I would run the turbo electronics, fuel curve and timing will not be correct for a non turbo. But on the flip side my sister ran her car for a few years with a turbo computer, it was a throttle body engine. If the track says anything tell them it is a Flex fuel vehicle, they used the turbo intake and MPI system. You could also use a flex fuel computer but the chances of finding one of them will be hard. Where you at in VA?
MarshallOne is offline
Old 07-10-2006, 03:35 PM   #3
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
i would go with a turbo wiring harness and computer and just zener diode the TPS so it never sees WOT
i would use 2.2 t1 injectors since they are the smallest with an AFPR, and tune it to where you need it
RPMurph is offline
Old 07-10-2006, 05:43 PM   #4
My Ride: 85 GLHT, 87 ShelbyZ
doesn't matter if you're floored or not the computer only gives the amount of fuel for the amount of vac/boost it see's. So if all you can get is 0psi then that's the amount of fuel you're gonna get. Turbo puters will run an n/a no problem. Just make sure to match the Map sensor to the computer.
GLHNSLHT2 is offline
Old 07-10-2006, 05:56 PM   #5
Engine: 2.2/2.4
yeah i thought turbo elec would be the easiest to run the 4 inj and still factory stuff. thx. anyone know of any differences in tb or carb exhaust manifolds in car or van?
IRONMURT is offline
Old 07-10-2006, 05:57 PM   #6
Engine: 2.2/2.4
will be racing at langley speedway, they all say a dodge will be too slow. we just want to prove them ALL wrong!
IRONMURT is offline
Old 07-10-2006, 08:06 PM   #7
You got my help. I live just down the street from Langley Speedway.
Old 07-10-2006, 08:11 PM   #8
A daytona was the Ucar champ a couple of years ago. I have been wanting to run at langley but being in the military it is extremely difficult. Let me know what you need I can definetly help. I am well known around a couple of the junkyards.
Old 07-11-2006, 04:43 PM   #9
if you need an FFV computer they show up in the junkyard here all the time. $50 plus shipping if i go get one for you.
Travis_k is offline
Old 07-11-2006, 08:51 PM   #10
Engine: 2.2/2.4
I think the turbo elec will work fine, if not you will def be getting a call.
IRONMURT is offline
Old 07-11-2006, 09:55 PM   #11
for a lot less money and a TON more performance, put on a carb. just call your car a 1983 Mexican Daytona, they cam carburated. then for really cheap money, use a 1986-1988 2.5 engine but install 1985 2.2 flat top pistons. this will get you the power you need to keep up with the Honda's. also spend a lot and I mean a lot of time on oil pan design to keep oil around the pickup tube. now to make the car handle, install a #350-#400 spring in the RR and #300-#350 on both fronts. this will give you a great starting point on making the car handle
allmotor is offline
Old 07-12-2006, 11:55 AM   #12
Engine: 2.2/2.4
you have to use injection if that year came w/it or carb if that year came w/it.
you can not do any internal modifications to the rotating assembley. i have all kinds of parts for the old mini stock class which was 4cyl unlimited but you can no longer use any of those parts. they are trying to make the class less expensive and more equal.
IRONMURT is offline
Old 07-12-2006, 02:59 PM   #13
Change F.I. from fuel injection to forced induction and you'll be ok.
15w/ashelby is offline
Pay Day Loans | Remortgages | Home cinema sound system | Boston Attractions | Mortgages
Page generated in 0.54494 seconds with 13 queries
