11-22-2006, 12:21 AM
My Ride: 87 GLHS & 73 Cuda
Thedodgegarage.com does a decent job of explaining. Here is a basic rundown:
G head flows about 10% more stock than a swirl, but the swirl makes more low end torqe and better response. With TII pistons, the G head will be around 7.8:1 CR, while the swirl is 8.1:1. Ported, both heads respond nicely. The valves in the two heads cannot be swapped because of different stem heights. I prefer the swirl head because of the higher compression, and the swirl effect in the combustion. If you have a cal for a swirl, it is not best to swap to G head without a recal, and vice versa. Both heads are non-interferance, so don't worry about valve clearance.
For a dirt burner, the swirl makes the torqe and the response, but the G head will flow more in the RPM and make a little more top HP. A good ported swirl would be great because it still makes the torque and can flow some high RPM also.
11-22-2006, 12:51 PM
I would assume he's talking N/A so those compression ratio's are too low.
11-22-2006, 09:33 PM
TBI cams are the best, turbo cams are limited in lift and duration. For rollers, the 88 TBI is the largest one.
11-23-2006, 03:25 AM
Try advancing the timing, your not going to get any more power using a turbo grind.
Magnum 318 springs are a cheap upgrade and have some nice spring pressures, check out the PT lifter thread-labeld Conical valve springs.
