12-04-2006, 10:40 PM
anybody had bent rods from flooding?
My Ride: 89 daytona/85 laser
Im working on a guys truck (95 dakota 3.9 magnum) who says to me that when he parked the truck it was running perfectly but when he came out of the store it wouldn't start.
so i got it home and looked it over and the coil resistance tested bad , put new coil on and what do ya know nice bright spark I cranked it a couple of times to see if it would fire up and it sound horrible when cranking almost like there were no plugs in it checked compression and his average reading was 30-50 psi with one cyl in the back at 0 .could he have flooded it so badly that he bent all six rods ?
12-05-2006, 01:09 AM
Yes, but not fuel, probably sucked in some water and he's not telling you the whole story.
When I was at the dealer, a Tracker was towed in, was told it "just started running funny" did a compression test and two cylinders were low. Pulled the head and sure enough, those pistons were sitting down. I then checked the air filter housing, its on the side and you dont' need to take off the lid to remove the head, the filter looked like it was soaked and then dryed out. We confronted them and then the kid confessed to driving thru large puddles and didn't want his dad to find out.
12-05-2006, 05:24 PM
It does sound weird he swares it was running good and his passenger said the same but who knows It doesn't have compression is all I know. guess I will have to tear into it.
it couldnt be the timing chain slipping could it ? are these 3.9 v6 good motors ?
12-05-2006, 05:26 PM
The timing chain is more of a reality, as if it slips or breaks, it will bend the valves not the rods.
Its a good engine, just a 318/360 with 2 cylinders missing.
12-06-2006, 01:03 PM
well it was the timing chain, the gears are stripped is it possible the valves could be bent ? I have no idea if this is an interference engine or not
12-06-2006, 01:34 PM
Yep, all SBD, SBF and SBC's are valve benders when the chain breaks or the gears strip.
12-06-2006, 01:46 PM
thanks simon and 88 pacifica It looks like its not gonna be cheap fix no matter what. Im gonna put a chain and gears on and do a compression test but Im afraid the valves are probly bent
12-06-2006, 02:04 PM
great idea might be some bent pushrods in there man my memory sucks I guess 5 screaming kids will make you forget a lot
12-06-2006, 02:55 PM
#12
Good idea on the pushrods, but yeah, I bet you have at least one bent valve.
Piston damage is extremely rare, I personally have never seen it and I have never heard of it, the valves are so soft they just bend over.
