03-10-2007, 05:55 PM
My Ride: '88 Plymouth Voyager
Engine: 3.0 V6
Dieselling can also be a sign your rings are shot, fuel might be shut off okay, but with bad rings it can suck up and atomise oil, which will then go bang if everything is warm enough. So if you've been seeing blue smoke, and using up oil as well, then plan for some $$$ work. However, there could be a faint possibility that the rings are just stuck down tight with carbon and something like AutoRX or Seafoam could fix it if used repeatedly. Check what the Wizard said before worrying too much though.
