05-21-2007, 06:49 PM
My Ride: 1987 caravan
Engine: 2.2 carb
Plugs, ingition etc were changed 2x, same results. Once on bosch, then mopar.
The wear on the terminals in the distributor is good, no cross fires, and no misses. Seems as it is firing but not combusting well in cyl 2, as seems as it's choked with too much exhaust causing the burn to be sooty?
Kinda mysterious. The manifolds were planed flat and with new manifold gasket in 2004 after compression check.
Cheers, Wizard
