07-10-2007, 05:38 PM
No, unfortunately bigger mods like cutting the floor for the 520+ cable shifted setup instead of the L body rod shift setup. I have heard some about people being able to mod the mechanical linkage setup yours has to work with a cable shifted trans but I've never seen one in person. To convert to the cable shifted setup is a bit of a hack job IMO, but doable I guess:
L-Body A-555 Swap
Unfortunately, the 4-sp is the first in a series of three low-duability transmissions mopar made. See this page for some transmission background:
DDG- The Transmission Guide
I talked with one guy who was making a solid 200hp to the wheels on his 2.2, he toasted two or three 525's before installing one with a numerically lower final drive ratio, which he says held up. Heck, even the T2 shelby chargers that used the 525 were detuned by around 30 or so ft-lbs so the trans would hold, with the 525 being stronger than your trans. The auto trans was pretty much the same way, power output was detuned for them, so I wouldn't push them overly much over stock.
