Old 08-17-2007, 06:11 PM   #1
Dumb Newbie Question - Fuel Tanks...
My Ride: 1985 Dodge Omni GLH
Engine: 2.2L Carb
Can you use a T1 Tank and sender with a carb (N/A) car???
I want to use a mechanical fuel pressure regulator and get rid of the mechanical pump. Run all new lines and loose the charchol filter and most of the vac lines.
Still undecided if I will be running a 36/32DVG, or 40DCOE's....
pipeguycan is offline
Old 08-18-2007, 02:53 PM   #2
Mitsu Booster
Works for other cars converted to carb so it should be ok. Get a good pressure regulater
karlak is offline
Old 08-19-2007, 01:20 AM   #3
Electric fuel pump
My Ride: All of them
Engine: 2.1 T1
Just make sure you turn the pressure down to about 6 psi max. Otherwise the electric fuel pump can override the floats and flood the carb.
mike mckay is offline
Myspace Layouts | Loans | Wills | Cowboy Bebop Episodes | Finance
Page generated in 0.35602 seconds with 13 queries
