Old 09-20-2007, 10:43 AM   #1
Proformance Mod's
My Ride: 1991 Dodge shadow
So i just accuqired a 90 dodge shadow and its my first car. Its a 2.2 and i need to know wat are some mods for that that will make it go faster.
gizmo719 is offline
Old 09-20-2007, 02:08 PM   #2
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
good tune up, CAI, exhuast, TB spacers(extra gaskets), remove balance shafts, mill the head......not really much you can do...read the faq
you could do a turbo swap
RPMurph is offline
Old 09-20-2007, 02:46 PM   #3
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
Feedback: (29)
Images: 166
Get a minivan airbox, it will less restrictive. Then route a cold air intake. Keeping th efactory Shadow airbox won't get you any where
2.50" exhaust, hi flow cat and muffler
+1mm Valve's, port the head
port match the intake manifold to the head
port the exhaust manifold alittle bigger then the head ports
underdrive pulley
make a spacer ~ 2 or 3 throttle body to intake manifold gaskets
That is all I can think of to try
-Clayton Dennis ~ Forum Admin
1987 Shelby CSX #674
1985 Dodge Omni GLH
moparfwdsleeper is offline
Old 09-20-2007, 10:03 PM   #4
Images: 9
for the intake I would go with an omni top end an a v6 lower end, then use dryer hose and route it under the car....makes for a nice CAI...thats what I have on my spirit.
or I had this idea to take an omni airbox, cut it before the airbox part, like on the part right after it connects to the TB, and heat up the plastic enough taht I could slip it over like a 2" hard pipe
IMO porting would not really be worth it on a TBI engine, the intake manifold is so restrictive it wouldn't make much of a difference. but maybe i'm just thinking that because of how much a difference it would make n/a vs turbo
you could swap to MPI and use a turbo manifold and run the injectors batch fire, or use a turbo wiring harness and zener diode the TPS so it never sees WOT and it should run fine
RPMurph is offline
Old 09-20-2007, 10:14 PM   #5
Images: 9
CAI
notice the hose:
had to switch to studs!
RPMurph is offline
Old 09-20-2007, 10:44 PM   #6
Feedback: (29)
Images: 166
I'll agree the intake is restrictive. But my thoughts on porting it goo back to the more air you get in and the more air you get out = horseoiwer and torque gains. The cylinder head would benefit you if ported and oversize valve where put in as it goes with the same statement above, makes it less restrictive, allows more air to move in and also move out. I have never seen an omni airbox I would go with one off an omni now
The less restrictive you can make the air flow the more youll gain. Will you ever hit 250HP? Highly unlikely, but 170 or so I would put money on it...
A turbo swap would wake the car up with no doubt... But without a complete parts car on hand it can be a PITA ~ I learned this with my first turbo dodge attempt ~ 1994 Dodge Shadow ~ I had the parts car, but it came with an automatic transmission - not a 5 speed like i needed.
1985 Dodge Omni GLH
Old 09-20-2007, 11:37 PM   #7
Images: 9
with alot of porting and alot of compression you might be able to get 170 hp\
allmotor hit 350hp n/a.....tall block, stroked to a 2.8 with a custom billit crank, 14:1 compression, .650 lift cam, he was running carbs tho. I can only imagine how muc torque that thing had, I wouldnt be surprised if it was 500ft/lb
RPMurph is offline
Old 09-20-2007, 11:41 PM   #8
Feedback: (29)
Images: 166
I didnt know that about him that is crazy! thanks for the history lesson Carbs vs. TBI winner Carbs
1985 Dodge Omni GLH
Old 09-22-2007, 12:46 AM   #9
ok thanks this weekend imma tune it up and put a CAI on it.(hopefully) so do turbonatars really work?
gizmo719 is offline
Old 09-22-2007, 12:29 PM   #10
Feedback: (29)
Images: 166
no they dont!
1985 Dodge Omni GLH
Old 09-22-2007, 01:02 PM   #11
yea i just figured that out a friend has one. thanks
ok so back to the turbo do i need the 5 speed to turbo it of will the 2.2 engine be fine?
gizmo719 is offline
Old 10-22-2007, 01:36 PM   #12
Re: Proformance Mod's
jus a dumb question/suggestion has anyone ever tried using the 2bl carb intake and bolting on the v8 tbi unit off of say a 90 dodge ram with a 318 or 3.9 v6? i always wondered if anyone ever tried that.
neontj is offline
Old 10-22-2007, 05:19 PM   #13
yeah....stroker motor, especially if you don't have a turbo. the 2.5 has more bang for the buck than a 2.2. my dynasty was quicker than my k sedan.
capev86 is offline
Old 10-22-2007, 05:20 PM   #14
600 lbs heavier and a 2.5 instead of 2.2
capev86 is offline
Old 10-22-2007, 05:22 PM   #15
i'd love to know where you can get the stroker crank for the 2.5 tall deck block.....maybe i should keep the old motor out of my 86 k wagon?!!
capev86 is offline
Mortgages | Money | Bargain Flights | Loans | Myspace Layouts
