11-25-2007, 04:43 PM
Re: Carbed distributor question
My Ride: 1987 caravan
Engine: 2.2 carb
Not like leanburn was.
Carbed 2.2L all got the computer control spark. Controls extra 200rpm on the throttle with a throttle closed contact pad and antidieseling solenoid (only on while key is in RUN and start positions, this one is not under computer's control.), monitors the coolant temp and manifold vacuum (for spark advance timing.) and emissions.
Some have 6520 carb that requires one-wire O2 sensor. Can convert carb to weber (recommanded) or 5220 carb if you are allowed to drop kick the 6520 carb.
Cheers, Wizard
