Old 01-23-2008, 07:25 PM   #31
Re: How fast are NA omni's?
My Ride: 86NewYorker88Horizon
Engine: 2.2 TI /2.2 tbi
Images: 19
Originally Posted by vntned View Post
It would take a nice GLHT or some old skool Mopar for me to get rid of my GLH! Especially with the MP autocross springs Ive got on it, 1.25'' front sway bar, Addco 1'' rear bar, MP cam, sintered followers, MP valve springs, hooker header, NOS GLH muffler, and the list goes on.
I know most people just convert there Omni/Horizon to Turbo but I love my Carbd GLH! With no more than a header, exhaust, cam and a little head milling and you can be as fast as, or faster than a stock GLHT. With these mods my GLH never got a chance on the track, but on the street it could would stay side by side with my cuzs modded '98 R/T neon that ran 15.0s at 91mph!
wow that sounds like a fun car, not one i'd get rid of too. get that puppy fixed.
srt-rex is offline
Old 01-24-2008, 01:08 AM   #32
My Ride: 94lebaron 87sundance
Engine: 3.0l/2.2-2.5tubro360
Images: 13
3 years a go i built the glh when we first got it i was runing a 1.33-6 lap after building to motor porting the g head and intake weber carb backcuting the valves the cam was a custom grind stock lift lots of duration balanced and blueprintred bottom end . 5sp 3.73 gears koni coil over front and rear,3" header back to a flowmaster,msd coil and box was able to get to glh down to 1.26 and that was with 6 year old hard as a hockey puck ra1 tires (budget ran dry) rims were from a golf gti wider &. lighter At the end of the season the car was involed in a t bone we were going to take 1st place when a car a lap down decided to make a left turn glh pealed the neon open ending year 1. after rebuilding to body and converting the wirng to 89 omni tbi making way for batched fired 89 turbo 1 itake but i never go to install the 2.5l tall block t1 rods and flat top 2.2l pistons , gapless rings,remove balance shafts,ported swirl head alu flywheel . sold the car 6 months ago to make way for other projects
BAKES is offline
Old 01-24-2008, 07:07 PM   #33
MEOW!
My Ride: lebaron
Engine: 2.2L TI(ish)
Images: 137
wow beautiful GLH!!!!!
turbomini is offline
Old 01-24-2008, 10:05 PM   #34
I've worn lots of shoes
itsbudda's Avatar
My Ride: 1987 Lebaron
Engine: 2.2L Turbo 1
Images: 30
Yeah. Tis beautiful.
BUUUUH! DANG IT BOBBY! - Hank Hill
Jason Betsch._________________________
1987 Chrysler LeBaron Coupe- Needs work. :)
1993 Ford Ranger-shot ball joints, sensor problems, Just your typical ford :)
ShelByQue FTW!!!
MEOW!!!!
I'm looking for an overhead console for a J/G body with a blue interior, and a working compass. if anyone knows of one, please pm
itsbudda is offline
Old 01-24-2008, 11:20 PM   #35
Images: 19
Just curious how fast would a tbi 5speed stripped omni be with a decked ported head with back cut stock valves, cam, ported stock intake manifold, header, and exhaust be? If these carb'd cars were doing well would a tbi car be that much better?
srt-rex is offline
Old 01-24-2008, 11:37 PM   #36
Images: 13
the tbi was little bit slower that why i put a 89 turbo 1intake, 52mm throttlebody and use 19lb injectors form jeep 4.0l and turbo fuel pump. made a big diff wish i had made a n/a cal for it
BAKES is offline
Old 01-24-2008, 11:38 PM   #37
itsbudda's Avatar
Images: 30
I think TBI would be about the same. If you go mpi though, there'd be quite a difference.
ShelByQue FTW!!!
MEOW!!!!
itsbudda is offline
Old 01-25-2008, 12:21 AM   #38
Images: 19
hmm, i have a one piece intake and t2 fuel rail taking up space. do you think the tbi header would be a big restriction with a good exhaust on this setup opposed to a long tube? you ran the mpfi with what computer?
srt-rex is offline
Old 01-25-2008, 01:05 AM   #39
Images: 13
i batch fired the injectors using a stock 89 tbi /5sp ecm used the whole wiring harness headlamps to tail lamps from the 89 omnni i ran along tube header but when it crack i put a ported stocker in place for 2 weeks wasn't as bad as i thought i would be i think headman headers still makes a header for Lbodies just make sure you put a flex pipe on the colector that is how i cracked it i also heat wrap the header for end to end which help control the under hood temps
BAKES is offline
Old 01-25-2008, 01:13 AM   #40
Images: 13
i have seen turbo 1 LM and harness used that was leftovers for t2 upgrades but i always thought you need to add in some timing advance somehow
BAKES is offline
Old 01-25-2008, 01:31 AM   #41
Images: 19
this is a very cool idea, when you say you batch fired do you mean you took the wiring for the single tbi injector and spliced it for the 4 mpfi injectors?
srt-rex is offline
Old 01-25-2008, 02:37 AM   #42
Images: 13
yes i made a jumper harness from the old tbi injector that to the new injectors wire them a series / parallel to get the ohms right ran it for 3 month no problems but i wanted to put a injector driver in place for racing was worried about overheating the ecm i think mitso 4 cyl used them
BAKES is offline
Old 01-25-2008, 12:12 PM   #43
itsbudda's Avatar
Images: 30
you could always get the computer from a mexican model.
ShelByQue FTW!!!
MEOW!!!!
itsbudda is offline
Old 01-25-2008, 03:42 PM   #44
Images: 13
dam i miss that car now but on a lighter note i bought a 2.5 l turbo omni ice racer last night
BAKES is offline
Old 01-25-2008, 04:47 PM   #45
Images: 19
awesome i bet that engine gets the car moving well. just curious, why did you chose the screen name bakes? i ask because my last name is baker and i've been called that before.
srt-rex is offline
» Dodge Turbo Chat
Title, Username, & Date
