Old 03-10-2008, 01:31 PM   #1
tbi ideas
i have a sum what different ideal for a tbi car. i'm assuming that the bolt patterns are all the same on the 2 bl carb manifold is the same as a standard 2bl carb flange. if they are why dont some one take the carb manifold and install the dodge truck tbi unit which is a 2 bl all the sensors should plug in. my only though would be that the injectors would be way to big but a lower pressure or some good mods should lean it out decent enough. and my last concern would be wireing in the injectors to work properly so any thoughts, or am i off my rocker thanking this may work and be a good solution.
neontj is offline
Old 03-10-2008, 04:53 PM   #2
Re: tbi ideas
The Pope's Avatar
the V6 / 318 TBI is a 500 CFM TB. Thats too much. Holley sells a 400 CFM 2 barrel, which is still a little big. Then fuel pressure changes with a wideband. comb the junk yards for a Jeep of something that uses a larger bore 1 bbl TBI that you can use. Then there is a Weber or a Demon 350 2 barrel.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Old 03-18-2008, 01:30 PM   #3
Re: tbi ideas
My Ride: 86 Omni SE auto
Engine: 2.2 'GLHS style' TII
Feedback: (26)
there may be some benefit to adapting either the stock TB or perhaps a larger TB (as Pope suggested) to an earlier 'carb'd' mani, since they are sposed to flow better
there are certainly some opportunities to modify the stock TB and stock TBI mani to flow better also; also adding a CAI will certainly help
if I was modding a TBI car I would spend some time on the intake mani, exh mani, head ports, and TB to lightly port / clean them up ; and I would save up for a decent header (not sure if Hooker makes em for us anymore ?) and accompanying exhaust system
realistically, the stock TB wont be a major performance restriction unless you have made other improvements in engine breathing, like a larger cam and exhaust
detobias is offline
Mortgages | Repair Bad Credit | Credit Card Consolidation | Loans | Credit Card Consolidation
Page generated in 0.27120 seconds with 13 queries
