05-04-2008, 01:47 PM
Re: 84 2.2 carb replacement?
My Ride: 1987 caravan
Engine: 2.2 carb
Weber is very GOOD choice if you can find low miles condition on ebay (no rusty, clean looking weber) or buy from carbsonly.com and talk to their tech line.
Go with Weber 32/36 DFEV and box of jets, if you bought used weber, order 137 main, 165 air and idle 60 jets to get you back into original configuration and start tuning from it. Also wideband O2 is recommanded. You WILL need to work on the linkage taken from old carb or junk holley carb (carefully grind off mushroomed center till you get all flat then wiggle off the linkage lever, then grind all other extra stuff off except choke linkage, throttle valve and throttle cable pins, and with slim flat diamond file to widen the flats ever slightly to get fit on the weber's shaft. You want precise fit.
There are no good holley carbs out there, except NOS ones and extremely expensive. Go with Weber.
Cheers, Wizard
