89 Horizon 2.2 Tbi Upgrades??? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 6 Old 10-15-2008, 05:29 PM Thread Starter
My Ride: 2004 Suburban
Engine: 5.3
Images: 8
I have an 89 Horizon 2.2 auto : ( and shes not doing to well in the power department. What can i do to give it a little more power without converting it to carb or having the head done. Still have the stock muffler and the cat still on, and the stock intake. I do have a turbo and manifold off of a caravan but dont know how the motor would take to it, it has 78k miles on it. If anyone has any ideas let me know, and ive already been on the allpar.com 2.2 page and havent tried any of those.
3.0ShadowES is offline
post #2 of 6 Old 10-15-2008, 05:36 PM
My Ride: 86 daytona cs
Engine: 2.2 t1
Images: 3
Re: 89 Horizon 2.2 Tbi Upgrades???
You could get a larger exhaust and a underdrive pulley.
thedon809 is offline
post #3 of 6 Old 10-15-2008, 05:47 PM
Garrett Booster
My Ride: 1993 Dodge Shadow
Engine: 2.4L
somethings you can do, but before you do these, clean up the motor and everything.
Solid mounts
new timing belt
champ 438 plugs
new wires
Spacers
2.25in exhaust
long tube header
k&n filter
These make a different that you will notice.
Also, if you can, swap a 5sp.
Paczki is offline
post #4 of 6 Old 10-15-2008, 06:02 PM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Engine: 2.5 TII+SMEC+.60/.63+2-piece+SRT4 IC+no B/S ;)
Start with a FULL tune-up (including fuel & air filters) & check/replace timing belt (<20$) ...
then - decide how much money vs time you got , and how much U want to spend on the project; I would prolly spend some $ on tires/brakes/suspension ; thats a diff topic
easy stuff in order of expense
hacksaw off muff (and cat if legal where yur at) ; replace with straight pipe
remove AC belt ; if not working pull pump lines condensor
remove PS belt ; pump too?
retard cam 4deg
K&N drop in or homemade CAI w/ cone
underdrive pulley (UDP)
new 2.25 or 2.5 exhaust; got $$ , add a longtube Hooker
difficult but cheap
port exh mani
port head
mill head for CR bump
5sp swap!
turbo swap
detobias is offline
post #5 of 6 Old 10-17-2008, 09:49 AM
My Ride: Starion
for about $60 and a few hours of your time, you can gain about 15-20hp. and no it's not a snake-oil trick. just have the head milled about .040" it's not enough to upset the tbi system, barely effects the cam timing (not enough to notice) but you will definitely notice the power gain. however it would be advise able to run 89 or better fuel.
going with the other inputs.. check your ignition timing and cam timing (that the belt didn't jump) with ignition timing, verify it's advancing to at least 34 at 3000 rpms. and that you have 12-14 base timing at idle with the coolant sensor disconnected
pobort is offline
post #6 of 6 Old 10-17-2008, 08:39 PM Thread Starter
Engine: 5.3
Images: 8
Well i just did the cap rotor and plugs, i did get the champ 438s, and a stock new cap and rotor for the meantime and its a hell of an improvement over what i started with. Ill prolly order some stuff from fwdperformance. And in the junkyard today i found a 5spd omni im thinking of getting for the swap.
Human Verification
