07-31-2004, 04:06 AM
87 Horizon, carb to MPI setup.
Ok all. I have an 87 plymouth Horizon, carb, auto, ect. I'm going to be converting it to MPI this upcoming weekend. All of the parts will be from an 85 Shelby Charger parts car. I'm going to grab the complete wiring harness for the entire vehicle, the fuel tank, both computers, intake manifold, TB and all sensors. The whole shebang.
My only question is, since I'll be converting this thing to MPI, and obviously using the original turbo computer, injectors, ect, will there be any negative effects on using the turbo setup on a non-turbo engine??? I'll basically be making a higher-compression turbo engine setup, with no turbo. I can deal with a constant "power loss" light just as long as there is no adverse performance effects. My goals are both improved performance and higher gas mileage. So what do all of you experts think and recommend??? Is this doable, and if all works out properly, how much better gas mileage/performance should I expect???
Any and all help/comments/dire predictions are welcomed and appreciated. Thanks!!!
08-09-2004, 12:53 PM
The only problem is too much fuel at WOT.
Best bet is a custom cal.
08-13-2004, 07:28 AM
#14
As I said above, it won' be turbocharged until I get a longblock and the turbo rebuilt. Until then, it's just going to be MPI. And also, you have to pull the head to swap manifolds???
Nope, which was going to be my next point.
On a NON turbo car there is enough room to swap the manifold without pulling the head, even if you use the t2 intake. He is using the early t1, which is even easier! In fact, arguably, using the early t1 is good enough if you just want the reliability of FI with perhaps a few more HP as it is so low profile its very easy to work with. Also, 85/86 T1 electronics are easier to find. If you use a t2 intake you need to add the 86/87 add-on harness 2 the t1 harness and use an 86+ dist/hep.
Here is the mod - simplified.
Take 1 complete wiring harness for your application with both computers and all solenouds and relays.
Take 1 early t1, t2, or 2 peice intake manifold with fuel rail,injectors, harness, tb, and sensors.
Bolt on the manifold.
Attach the wiring.
Replace all rubber setion of fuel line with hi-pressure Fuel Injection hose.
Replace fuel tank with tbi/turbo style tank
Use turbo fuel pump.
Done. <------
BTW, since no one bought my 87 Carb horizon (I couldnt seem to give it away) I am doing this exact mod (with a T2 intake).
