08-27-2004, 03:21 PM
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
wait a min...... you are putting a tbi setup from a 2.2 or a 2.5 on the 2.6 motor? you are going to have to use an appropriate wiring harness from a newer tbi car that you steal the tbi unit off of. then you are going to have to make an adapter to bolt the tbi unit to the 2.6 intake manifold. then you are going to have to adapt the 2.2/2.5l distributor to the 2.6 or modify the 2.6 distributor electronics to work with the tbi ecm. then somehow you plan on putting a turbo on it?
quite frankly, youd be better off putting an entire 2.2/2.5 turbo car drivetrain in it and it would be much easier.
you could also gank a 2.6l turbo setup off of a conquest/starion and adapt the wiring harness to work with the 82 400 stuff. that wouldnt be TOO difficult....
if you want help with this project you are going to have to be a little more clear on exactly what you want to do and realistic with your goals.
Brian
08-27-2004, 10:17 PM
Engine: 2.5L T2
ahhh gotcha... it was confusing the way you worded it. its clear now. is the tranny a regular 413? you might be able to use parts from the 413 in it and newer 413's to get a stronger trans though i think it still will have the old style differential unless you can swap the newer style into the older case and large spline axles as well. that would be a cool setup. remember youll need to get the entire conquest turbo motor as the N/A internals arent as stout. the hardest part will be figuring out how to splice the star/quest harness into the 400's. get some wiring diagrams and go to town.  good luck.
Brian
08-28-2004, 12:35 PM
#13
Engine: 2.5L T2
That will be a cool project, you might wanna upgrade to a larger turbo from the getgo, since the turbo is tiny and usually fails because of its size. You'll have to cobble I/C piping, but that's easy.
Brian
08-29-2004, 04:40 PM
#15
well, depending what comes on those motors theres probly a cheap upgrade from another mitsu turbo motor that would bolt right on..
ive always wanted to do what you're planning, i hope you can pull it off.
also, 413s on 2.6s carent called the same thing.. its like 460 or or something, same tranny, different bellhousing, just like 670, and yes you can definitely beef it just like any other 413.. and the spline differences were on the outside of the axles, not the inside, so all axles should fit in there..
