10-16-2004, 12:52 PM
since its for a carb car, it its gonna need a fuel pump blockoff plate that your common block doesnt have on it.. check, since it is an 86-87 engine, that it doesnt have a slider cam.. if it does, i would put your cam setup in that head if you dont want to transfer the whole head. also, is your shadow a 2.2?? if yours is a 2.5, be aware that the engine you're looking at is a 2.2.
other than that i think it will work fine!
