12-22-2004, 07:45 PM
Originally Posted by capev86
yeah, atleast one guy has swapped a 2.0/2.4 DOHC setup onto a 2.5. there is a lot of machining and custom fab and other special considerations involved. probably have to run modded turbo electronics or neon dohc wiring w/ some custom programming/calibrations id gather. and then there is the exahust system to consider!
the 2.5 w/ a dual cam head will give you both high end breathing and low end grunt. factor in a little car like an omni with a good 5spd swap and youll be kicking butts at every stoplight!
Lots of guys have done it, the 2.0L and 2.4L Neon heads bolt right on, Cindy is even making hybird cam sprockets. Thats why I said to go over to 16v conversion. I will also be doing one if money works out.
Chadxton, if you read, he will be running a turbo set up, not N/A and the 16V thread is for turbo or N/A,
