Old 07-25-2005, 10:41 PM   #1
87 ply caravelle injector
hello, i have a 87 caravelle 2.2 bone stock, not souped up but it gets me to work, problem is its going thru a injector every two weeks. when the injector goes it runs rich. relplace the injector and it runs great 27mpg. i replaced the fuel pres. reg. i have no clue whats killing the injectors but im at 5 at $100 a pop. any help would be great. thanks bob
shape is offline
Old 07-26-2005, 11:01 PM   #2
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Here's my check list:
-voltage to injector should be battery voltage of 14.5 or less (13.2 min.) Too much voltage probably won't harm the injector but...
-Fuel filter completely rusted on the inside and is passing junk to the injector. Btw, when was the last time that was changed?
-deteriating metal fuel line between that freshly replaced fuel filter and the TB contributing rust to the fuel supply.
If you have more information that would help.
mpgmike
'88 Daytona Shelby
'91 Spirit R/T
'84 Rampage
mpgmike is offline
Old 07-28-2005, 12:38 AM   #3
injector
thanks for the reply. the problem seems to be the injector after about two weeks starts to dump too much fuel and i get real poor milage. replaced both the computer and logic mod. and the fuel reg. snap on scanner shows code always running rich but the inj. p.w. is normal. the o2 sensor is pegged at .98 i have no way of testing the fuel pres. but i suspect its too high possible damaging the injector. could the pump be putting out to much pressure? as i stated once a new injector is install the motor runs perfect for about two weeks thanks again bob
shape is offline
Old 07-28-2005, 01:08 AM   #4
If your getting rebuilt injectors, there probably bad. I stopped using rebuilt ones and by new unless my customer is a non-regular and insists on a rebuilt one. If they are indeed rebuilt, get brand new one, bet it lasts longer than the car.
High fuel pressure won't damage it either!
Mbna | Personal Loan | Loan | e Harmony | Plane Tickets
Page generated in 0.28957 seconds with 13 queries
