Ram 2500 shaking while idling - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > Cummins Turbo Diesel
Cummins Turbo Diesel Repair and performance for the Dodge Cummins Turbo Diesels.
Old 01-05-2008, 08:12 PM   #1
My Ride: 2500 cummins Diesel
Cowtowndodge is keeping the peace
Hey guys I am pretty new to the forum and need some help with a problem I am having with my 2003 Ram 2500.
When my truck is idling, it shakes pretty bad, but when I drive it is fine... I don't know what is happening and the boys at the shop can't explain it either...
Has anyone experienced this before?
Thanks,
C
Cowtowndodge is offline
Old 01-05-2008, 08:20 PM   #2
Re: Ram 2500 shaking while idling
Hybrid Booster
My Ride: 1989 Daytona Shelby
Feedback: (8)
ShelbyMopar89 is keeping our cars running
I have an 03 2500 HEMI so I can't help all that much. I can tell you that dodgetalk.com is the place to go, those boys are on top of it for the Rams.
ShelbyMopar89 is offline
Old 01-06-2008, 05:25 AM   #3
TopRedLine.com is keeping the peace
what he said
TopRedLine.com is offline
Old 01-06-2008, 01:02 PM   #4
Garrett Booster
My Ride: 94lebaron 87sundance
Engine: 3.0l/2.2-2.5tubro360
Images: 13
BAKES is keeping the peace
had to send injectors out for repair water go into to fuel supply and pluged up the nozzels causing the to spatter insead of spray on a buddys truck
just something to think about
BAKES is offline
Old 01-06-2008, 01:10 PM   #5
Garrett Booster
Images: 13
what you need is too get a scan tool on it (drbIII) and see what the data is telling you its a lot cheaper then just throwing parts blindy at it. diesel parts can get very expensive fast
BAKES is offline
Old 01-06-2008, 02:30 PM   #6
NAJ's Avatar
Feedback: (21)
Is the check engine lamp illuminated? If so you need to use an OBD2 scanner and retrieve the fault codes.
Symptom List:
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER # 1 MISFIRE
P0302-CYLINDER # 2 MISFIRE
P0303-CYLINDER # 3 MISFIRE
P0304-CYLINDER # 4 MISFIRE
P0305-CYLINDER # 5 MISFIRE
P0306-CYLINDER # 6 MISFIRE
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P0300-MULTIPLE CYLINDER
MISFIRE.
When Monitored and Set Condition:
When Monitored: While the engine is idling.
Set Condition: Misfire detected on multiple cylinders.
When Monitored: While the engine is idling at operating temperature.
Set Condition: Misfire detected on this cylinder.
116
DRIVEABILITY - DIESEL
POSSIBLE CAUSES
LOW FUEL
OTHER DTC’S
DAMAGED FUEL LINES
VALVE TRAIN
OBSTRUCTED FUEL INJECTOR SUPPLY LINES
DAMAGED OR OBSTRUCTED HIGH PRESSURE CONNECTORS
EXTERNAL DAMAGED FUEL INJECTORS
INTERNAL DAMAGED FUEL INJECTOR
NO COMPRESSION
EXCESSIVE ENGINE LEAK DOWN
TEST ACTION APPLICABILITY
1 Using the DRBIIIt, verify that the fuel level is above 15%.
Is the fuel level above 15%?
Yes ! Go To 2
No ! Add fuel go to step 2.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
2 Read the Freeze frame data.
Is the DTC equal to the freeze frame DTC?
Yes ! Go To 3
No ! Repair any other DTC’s first.
3 Visually inspect the injector supply lines for damage.
Do you have any kinked or bent fuel lines?
Yes ! Repair or replace damaged fuel lines.
No ! Go To 4
4 Visually inspect the valve train and check the valve lash on the suspect cylinders.
Is the valve train functional and the lash within the specifications listed in the
service manual?
Yes ! Go To 5
No ! Adjust the lash or fix or repair any damaged component(s).
5 Remove the fuel injector supply lines for the suspect cylinders.
Inspect both ends of the fuel injector supply lines for damage.
Using shop air pressure, blow out the fuel injector supply lines to verify that they are
not obstructed.
Are the fuel lines free of debris or damage?
Yes ! Go To 6
No ! Replace the damaged or obstructed fuel injector supply lines.
6 Remove the high pressure connectors for the suspect cylinders.
Inspect both ends of the high pressure connectors for signs of damage.
Using shop air pressure, blow out the high pressure connectors to verify that they are
not obstructed.
Are the high pressure connectors free of debris or damage?
Yes ! Go To 7
No ! Replace the damaged or obstructed high pressure connectors.
7 Remove the suspect fuel injectors.
Are the fuel injectors damaged?
Yes ! Replace the external damaged fuel injectors & high pressure
connectors.
No ! Go To 8
8 With the DRBIIIt, erase DTCs.
Switch the misfiring injectors & high pressure connectors with injectors & high
pressure connectors from cylinders that are firing properly.
Operate the vehicle.
Did the misfire DTC follow the suspect injectors & high pressure connectors?
Yes ! Replace the internal damaged fuel injector and high pressure
connector.
No ! Go To 9
9 Perform engine compression test
Did the suspect cylinders pass the compression test?
Yes ! Go To 10
No ! Repair the internal damage to the engine.
10 Perform engine leak down test
Did the suspect cylinders pass the leak down test?
Yes ! Test Complete.
Jan
1990 Daytona Shelby VNT
34 Years ASE Certified
Old 01-06-2008, 05:04 PM   #7
The check engine light is not on but I will check out dodgetalk.com to see if there is anything there. Also, when I turn the truck off the whole truck shakes pretty violently - could this be part of the same problem?
Old 01-06-2008, 07:27 PM   #8
Hybrid Booster
Feedback: (8)
Engine mounts?? Does it really wrap back and forth when going from Drive to reverse?
Old 01-07-2008, 01:48 AM   #9
Not so much when I go from drive to reverse, but just when I am stoped and have the gear in drive or reverse.
Old 02-07-2008, 05:28 PM   #10
My Ride: 03 ram 2500 CTD
ian515 is keeping the peace
they shake on shutoff is known as the "cummins shake"...its totally normal.
as far as rough idle, does it have a hard time starting? extended crank? try changing your fuel filter, make sure you have some fuel additives. also try turning your key on, key off, and key on again, then leave it on...if there are any codes, it will pop up in the odometer window.
I am going through an all out injector replacement, it isnt pretty....so hopefully thats not whats wrong with yours. also, if you dont find what you need here, or at dodge talk, try dieseltruckresource.com every thing you need and then some...
good luck!
ian515 is offline
Old 02-09-2008, 04:24 PM   #11
I put some additive in today and hopefully in a few days it will be better. I really don't want to put in new injectors either.... We will see. There are no codes showing up and the dealer didn't find any codes either, so hopefully it just needs a bit of cleaning.
Thanks for the advice.
Old 02-13-2008, 09:59 AM   #12
Garrett Booster
87shelby2.2 is keeping the peace
try cumminsforum.com also a very good resource
87shelby2.2 is offline
Old 03-06-2008, 08:09 PM   #13
My Ride: SPIRIT,VOYAGER,SRT4
Engine: 2.2/2.4
IRONMURT is keeping the peace
IS IT A MANUAL? have seen the exact symptoms: bad shake at idle, no dtc, fine when moving. was the clutch assembley - dual mass flywheel becoming unbalanced
IRONMURT is offline
Old 12-08-2008, 09:14 AM   #14
My Ride: 02' Cummins, 86' GLH
Engine: 5.9L Cummins, 2.2t
86GLHT2 is keeping the peace
gotta love that cummins shake............
86GLHT2 is offline
