Old 10-31-2005, 10:10 PM   #16
My Ride: 1981 Triumh TR7
Engine: none!
Induct: S/C
1/4: 999.999
I will look into an effective way to do that, we ran a small coolant reservoir from DangerZone with alcohol attatched to a washer pump an a boost sensing switch on the Merkur, I wonder if the same setup would work with the fact the boost is a bit more linear with the supercharger?
quasimofo is offline
Old 11-01-2005, 06:46 PM   #17
My Ride: Whatever runs
Engine: 2.7tt, 2.0, 2.5, 2.2
I think that it would be better to grab a high mileage 2.4l from 96 stratus/caravan complete for a couple hundred ($200), throw in SRT rods/pistons/rings/bearings ($300), bolt on a 5-spd from a dakota ($350) and run twin mitsu's you can probly get for $10 each on this site and run a harness from an 89 turbo ($50) with big injectors ($150) and a calibration from Cindy (($150) with twin SRT intercoolers ($200).
This should be bolt on except the custom exhaust. Use the rest of the money for BEER
88-16V-Lebaron is offline
Old 11-02-2005, 03:37 AM   #18
that would be a cool setup
QKsilverF1 is offline
Old 11-02-2005, 08:58 PM   #19
ednutcracker's Avatar
My Ride: 89' Dodge Daytona ES
Engine: 2.5 l4
both real cool ideas!!!
ednutcracker is offline
Old 11-02-2005, 09:17 PM   #20
Engine: none!
Induct: S/C
1/4: 999.999
Turbo still too peaky for what our intentions are. I AM building another 16V engine, a 2.5L turbo engine, but it is going to be for an extra special project after the TR7 is done. The Dakota trans is useless to me, but I do have a bellhousing from one that will be used. The guy who sets up my rear axles showed me two 2.2L NA Dakota trans with the input shafts destroyed from normal use... A T5 will be fine.
Old 11-02-2005, 11:57 PM   #21
yeah i definatly agree SC is the way to go for auto x
Old 11-13-2005, 07:43 PM   #22
Engine: none!
Induct: S/C
1/4: 999.999
Well the Dakota bellhousing will be here monday for the first rounds fo fitment, I am actually adapting the TR7 trans to the Dak bell instead of the T5. Less money in driveshaft and trans crossmember fabrication. Once the setup is complete and the mounts/manifold are finalized the actual build starts.
Old 11-16-2005, 03:32 PM   #23
Which bellhousing are you using? The old style one on the left or the later style one on the right?
http://www.turbododge.com/forums/att...achmentid=3325
Greg
Greg55_99 is offline
Old 11-18-2005, 07:21 PM   #24
Engine: none!
Induct: S/C
1/4: 999.999
The one I have is an old style.
Old 12-05-2005, 04:19 PM   #25
What cams are you planning on running? If you wanted to you could go to neons.org and fine a nice set of used magnum head cams, or even crane 12's or 14's for rather cheap. Or even still, if the head is slightly newer, get a set of cams from a 1995 neon, they have a slightly more aggressive grind, and slight overlap.
invujerry is offline
Old 12-05-2005, 08:37 PM   #26
magnum camS? magnum is SOHC
Old 12-06-2005, 12:15 PM   #27
Thats right, I have a SOHC, thats what I'm thinking about.
Old 07-08-2006, 09:56 AM   #28
So how did all of this come along anyway?
Credit Cards | Loans | Web Games | Car Insurance | Loans
Page generated in 0.56334 seconds with 13 queries
