Old 03-22-2006, 09:22 AM   #61
The Pope's Avatar
Originally Posted by SUPERVAN
You don't need to. There are benefits to running it all the time.
You should run it all the time like he said. However clutching superchargers have been around for many years. Basically a AC clutch on a supercharger. Hooked up with a hobbs switch you could shut if off where ever and then it idles.
The Pope is offline
Old 03-23-2006, 10:59 AM   #62
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
so ive rigged up my "paxton STYLE" blower, mounted it (not plumbed) and got all the belts hooked up and it it pushes a GOOD amount of air just at idle!!
blow moderatly hard on your hand and thats about how much air it pushes at idle! problem is the way i have my bearings. theyre too close together so the shaft still wobbles a bit. ill fix that soon. anyway, just an update. from looking at how the set up acted just at idle, im thinking its gona produce MAD amounts of boost and realy need to be regulated! it will be interesting to see how it all acts with the super 60 set up im already using.
turbo minivan is offline
Old 03-23-2006, 02:20 PM   #63
Pope, you have been helping me out alot lately. Thanks chris
I swear you must search every morning for my post to respond. Now off to the A/C clutch search day !!!!
cj011 is offline
Old 03-27-2006, 11:31 AM   #64
cam gear
have seen cam gears on e-bay
dodgedemon is offline
Old 04-03-2006, 07:14 AM   #65
My Ride: 88 dodge
Engine: 2.2 turbo 1.5
Originally Posted by cj011
any ideas of how to disengage the supercharger when the turbo spools?
Electromagnetic clutch assembly should disengage the S/C pulley, W\while on th \e topic of pulley smaller are more efficanent if you go larger you wil be losing horsepower since it will require mmore revs to turn a large pulley less to turn a small pulley.
fro example if you have a pull designed to run 1 to 1 (one revolution of the engine turns the pulley 1 time)
As opposed to a pulley designed to run at 2 to 1 (every 1 revolution of the crank turns the pulley 2 revolutions)
shelby1.5turbo is offline
Old 04-03-2006, 03:50 PM   #66
My Ride: 89 Dodge Caravan SE
Engine: 2.5 CB
Actually you have it backwards, I know what your thinking. A smaller pully makes more power because it moves more air, but your loosing efficiency by doing so. Just think of the SC pully as any ordinary accessory pully. If you were to put underdrive pullys on all your accessorys you would go bigger. The guys running twin charger setups I have seen go to bigger SC pullys because it is more efficient (less parasitic loss, not more power) and rely on the turbo for more/most of their power and just use a small amount of boost created from the SC to help spool a REALLY BIG efficient turbo. make sence?
SUPERVAN is offline
Old 04-05-2006, 08:38 PM   #67
My Ride: 88 dodge
I thing we both confused ourselves, ( well I am )I was refering to the crank pulley a smaller one on that. I mean look at top fuel drag cars the produce 4000-6000 horsepower but the loose horsepower with the pulley assembly I mean those things are usually bigger than a factory crank pulley. I also know were not talking about make a few thousand horsepower but certain teams run a smaller pulley to reduce the horsepower loss. It would be nice to make a 3000 horsepower mopar.
Old 04-06-2006, 01:40 AM   #68
The Pope's Avatar
fuelers make over 7,000 HP, it takes over 900 HP to turn the blower to 43 PSI of boost and the exhaust alone creates over 800 lbs of down force. They are not looking to make a few less HP, they are looking to get a few more HP to the ground. They don't run a smaller pulley because they want to save on power loss, they want to make less total power to hook. And that is only after clutch adjustment won't allow traction. NHRA keeps lowering the % of nitro they run to calm them down as the power level goes up. People that run 125 MPH in the length of the car and over 270 MPh in the 1/8 are not looking to save power in the pulleys
now people with centrifical blowers complain about pulley slip allot. That is an issue.
The Pope is offline
Old 04-06-2006, 03:41 PM   #69
Engine: 2.5 CB
They are not looking to make a few less HP, they are looking to get a few more HP to the ground. They don't run a smaller pulley because they want to save on power loss, they want to make less total power to hook. <---ok this confuses me< Are you trying to say they are looking to reduce power in order to hook up?
People that run 125 MPH in the length of the car and over 270 MPh in the 1/8 are not looking to save power in the pulleys. <---I would have to absolutly aggree with you there, but in the order of twin charging a street driving car or the average joe track car for that mattter, the case of bigger pully is better doesn't quit work. I would say with a SC only car go with as big as you can get away with.
SUPERVAN is offline
Old 10-19-2006, 11:54 PM   #70
My Ride: (2) 89 turbo caravan
Engine: turbo 2.5L
With twincharging do you run the turbo into the supercharger for added top-end performance. Or do you run the blower into the turbo? Does it matter??
cook is offline
Old 10-20-2006, 12:36 AM   #71
Engine: 2.5 CB
turbo into blower
SUPERVAN is offline
Old 10-22-2006, 10:32 PM   #72
Doesn't really matter if you're going to be disengaging the SC when the turbo spools. Does it?
yarcli52 is offline
Old 10-23-2006, 12:03 AM   #73
Engine: 2.5 CB
The SC does not need to be disengaged when the turbo spools even though there are systems like Volkswagons 1.4 liter motor in Europe that do so. Actually there is advantages to running boost into a supercharger like compound pressures and the fact you can run an air-to-air IC after the turbo and a water to air under the SC.
SUPERVAN is offline
Old 10-23-2006, 07:06 AM   #74
But the VW 1.4L is pretty damn efficient making 174HP. They also run only one IC i believe. So my question is, why change something that has already been successfully factory produced?
yarcli52 is offline
Old 10-23-2006, 12:13 PM   #75
check out vws diagrams ( plenty online ) it should be blower going to turbo, very simple layout , also a supercharger ( roots style ) does not compress air internally which i believe hes using . so you cant compound inside of a roots blower.
frostburner is offline
» Dodge Turbo Chat
Title, Username, & Date
Running PIG rich
