Old 12-06-2005, 12:28 AM   #1
supercharged turbo
My Ride: (2) 89 turbo caravan
Engine: turbo 2.5L
You guys must check out this car Its not a turbo dodge its a old opel manta with a 16V volvo 4cyl with a turbo supercharger setup hilmersson racing is the site check out the vids! Someone needs to buildup something like this only in a FWD dodge!
cook is offline
Old 01-03-2006, 02:59 PM   #2
im actually in the process of doing this to my vnt shadow. I started designing the setup awhile back and have been working on on and off since then. Im planning on running an m62 where the a/c is. I already have the pulley setup I will be using, tensioner bracket, and mounting. I will be using a 60/63 turbo and a custom header that yours truly has designed for these cars. To control everything im using a control unit to do my timing, fuel, and just about everything else a standalone does but for a minute fraction of the price( nice having friends in the industry ) Im hoping to have everything up and running later this year as time permits. I have access to a machine shop and dyno and everything else I need so I have all my bases covered. Should make for a very quick car as my shadow will be stripped and picked clean to reduce weight.
frostburner is offline
Old 01-05-2006, 07:47 PM   #3
My Ride: 87 Dodge Omni
Engine: I4 2.2l
One word.....PICS!!!!
Okay, one more.....PLEASE!!!!
Cooter is offline
Old 01-07-2006, 09:16 AM   #4
My Ride: 84 Buick Ttype Turbo
Engine: 3.8 Turbo
I saw a supercharged turbo setup on an old diesel v8 or v6 truck engine from the
70's. It was a 2 stroke engine to beat all and had a conventional blower setting on it with the turbo setting right on top of the blower. Wildest set up I've ever seen or heard of. I didn't even know there was such a thing as a 2 stroke diesel in the first place.
GNGUY is offline
Old 01-08-2006, 01:55 AM   #5
My Ride: Big Ramcharger
Engine: 364 '84 blk, '75 hds
Nissan built a car like that, but it never saw US shores. It was one liter, yes 60 CID, and came with a supercharger and a turbo. It was called the super turbo something or other.
Moparmonster is offline
Old 01-09-2006, 12:30 AM   #6
My Ride: need a TD
some people have done this to their mk1 mr2s.
they refer to it as twin charging.
some people are even doing it to their new mini copper S's.
krazy4 is offline
Old 01-10-2006, 06:19 PM   #7
this is the second time i heard of turbo'd 2 strokes..
how do you give a 2 stroke forced induction (without nitrus)?
me and my rc car would love to know.
BrassMonkey is offline
Old 01-10-2006, 06:43 PM   #8
My Ride: daytona
you gota show us some pics of that that sounds carzy:banaride:
you gota show us
shad0w2.S_tur80 is offline
Old 01-12-2006, 08:28 PM   #9
My Ride: need a TD
don't you just love that smilie:banaride: :banaride: :banaride: :banaride:
id highly recommend this setup if you can pull it off.
krazy4 is offline
Old 01-14-2006, 04:07 PM   #10
A little teaser, here is the twin inlet I will be using and the Monster Bov, and Air filter. I got lazy on drawing the airfilter so i just textured it lol. But everything is drawn 1:1 from what I have sitting in front of me. I also am using a custom dual injector block for the extra needed fuel. Ill post some other stuff later.
Old 01-16-2006, 12:51 AM   #11
My Ride: need a TD
^very nice work
krazy4 is offline
Old 01-16-2006, 10:18 PM   #12
Originally Posted by krazy4
^very nice work
thanks, some more i whipped up just now.
Old 01-18-2006, 04:45 PM   #13
My Ride: 1982 Dodge Rampage
Engine: 2.5 Turbo II
Slick work, I like.
I have one comment thou, If you have space to rout it, I'd put pants on that filter inlet as opposed to the tee.
[_______]
_[]_
\ / filter
Not this
_[]_
\ / filter
But This ;-)
I do duct and piping all day for industrial applications design and when velocities get over 1500 feet per minute it reduces the pressure drop segnificantly, as much as 1/2 psi. On an automotive application with velocities of 8000-10000 feet per minute (assuming a 3" inlet) pressure drops could be much higher
WLKIVETT is offline
Old 01-18-2006, 05:15 PM   #14
^^ yea ive been debating that, i actually have a few more intake ideas up my sleeve to try out, this is just the first one ive drawn up, ill probably work on the setup more tonight, changing my intercooler plans to running twins for relocation purposes.
Old 01-19-2006, 03:45 PM   #15
The Pope's Avatar
as easy as it would be I am supprised no one has tried a compounded turbo. Basically running T2 type injectors into a B&M intake and running a big TB on the blower. Then it is a matter of adding a big turbo to a stock turbo manifold. You can run allot of exhaust side on a compounded setup, stage 4 .84 trim exhaust with a big T4 compressor. Then there is no lag and no worry of spool up, the blower spools the turbo. Then the air going into the blower is compressed. So you have even more boost than the turbo puts out. This means you have more boost PSI than exhaust PSI, so even a bigger cam can be run. Allot of advantages, but haven't seen one yet. And if you happen to have a B&M setup it is a fairly easy thing to make.
The Pope is offline
Balance Transfer Credit Cards | Mortgage Loans | Loans | Mortgage Calculator | Codigo da vinci
Affiliates: GTcars.ca - DodgeIntrepid.net - AudiForum.ca - Miataturbo.net - CanadianCarAudio.com - StangFan.com - ProjectCamaro.com - HondaPoint.com - ChevForum.com -
