Old 12-17-2005, 05:57 PM   #1
which supercharger is easiest
My Ride: 89 GTC
Engine: 2.2T2
which supercharger would be easiest to install in an L-body 2.2l
gtcman is offline
Old 12-17-2005, 11:43 PM   #2
My Ride: 1983 N/A Rampage
Engine: Dodge 2.2L
B&M bolt on... if you can find one
Sirus is offline
Old 12-20-2005, 01:27 AM   #3
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
Depends. If you are willing to rid yourself of A/C, then you could use a M62 from the pontiac GTP. Make your self a bracket to bolt it up and you could then intercool it like a turbo before feeding into a throttle body. They use the M62 on the Cobalt SS, so it isn't too big of a supercharger. If I were going this route, I would use a 1 piece turbo intake. The hard part will be getting a computer to work. Megasquirt may be an option here for fuel and spark control as it is fairly cheap. Just a suggestion.
Andre Parker is offline
Old 12-20-2005, 01:31 PM   #4
supercharger from a gtp is a m90 not a m62
Jetson8294 is offline
Old 12-22-2005, 11:26 AM   #5
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
The older ones are M62. The newer ones are M90. I have one for a guy for a neon set up that he bought from the older GTP. There also avaliable from the ss boneville too
Old 12-22-2005, 02:27 PM   #6
why couldnt you just run T2 or even early T1 elctronics with it. as it builds boost then the fuel pressure will rise.? but do you get the sweet whine outta a M90 that you would get outta the olds rootsstyle B&M?
nate
turbottt1 is offline
Old 12-24-2005, 06:56 PM   #7
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
M62=93-95 GTP, Bonneville, Riviera.
M90=96-03 GTP, Bonneville, Regal GS, Riviera, Park Avenue Ultra.
There was also a version of the M90 used on the Thunderbird from 91-95. The later versions with the squared intake hole are the best.
Avenger is offline
Old 12-28-2005, 08:16 PM   #8
My Ride: 88 daytona pacifica
Engine: 2.2 turbo
They were used on the thunderbirds starting in 89 and the mercury cougar xr7's in 89-90. I had an 89
jre97 is offline
Mortgage Calculator | Dictionary | Remortgages | Mortgage | Remortgages
Page generated in 0.30475 seconds with 13 queries
