Old 05-14-2006, 10:24 PM   #1
turboing a 1982 horizon?
how hard would it be to drop a 2.2 turbo motor into a 1982 plymouth horizon 5 speed? i have a omni glh that was totaled out by the insurance company? would the motor mounts be the same? just swap the wiring and computer? both are 5 speeds. is the linkage and stuff the same?
thanks,
jeff
lowflying90 is offline
Old 05-15-2006, 10:26 AM   #2
http://www.thedodgegarage.com/ddg_faq.html -- it's easy to do if you know what your doing . . . getting everything swapped from one to another is the trick. Hope this helps!
BradleyMiller is offline
Old 05-15-2006, 12:48 PM   #3
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
No, the mounts are not the same... But, there were some L bodies in '82 with 2.2's, so you just need to track one of them down in a JY for the mounts.
Una is offline
Old 05-15-2006, 04:03 PM   #4
thanks,
jeff
What did you get a door ding?
How bad is the damage. Is it repairable? The insurance company will call almost any damage totaled just to get out of fixing it for more. How much did they give you for $$. You can make them give you market value of $2-4K instead of $500.
Make them give you the right amount of money or make them fix it. Don't total the car if not necessary.
Insurance A-holes piss me off.
85woodywagon is offline
Old 05-15-2006, 04:55 PM   #5
no, the kid i bought it from hydroplaned and hit a barrier screwing up the whole side and back end pretty bad. the car was already totaled out by him but i got him to buy it back and give it to me for cheap for the drivetrain.
Old 05-15-2006, 08:19 PM   #6
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
You'll need to swap over everything: engine, trans, fuel lines, fuel pump, actually the whole damn fuel system, the exhaust system, the computer, find some mounts as mentioned, all underhood wiring, I would probably swap the glh interior incl. dash and gauges as well. I dunno if the brakes and tires should be swapped as well, but I prolly would if you already have them.
Basically be prepared for quite a bit of work. But it is totally doable
daytonajesse is offline
Old 05-15-2006, 09:18 PM   #7
My Ride: Whatever runs
Engine: 2.7tt, 2.0, 2.5, 2.2
How is the hood and GLH spoilers?
Save the hood
88-16V-Lebaron is offline
Old 05-24-2006, 04:14 PM   #8
I have done several turbo swaps including carb to turbo. Carb to turbo is by far the hardest especially if a fuel injected engine was not offered that year. As long as yours is a 2.2 everything should bolt in. The problem is the harness, I doubt the bulkhead connector will be the same. Since you have a complete donor car and there really isnt much wiring in those cars, swap both the engine and interior harnesses. I didnt want to do this on my 84 because there is a lot more work wiring a van over your car so I heavilly modified the 90 turbo harness to work with my 84 interior harness, but it took a lot of time, patience and studying. You should be ok with the stock fuel lines, but thats about it. If you get in a bind let me know. But like I said just swap all the wiring and save yourself the hassle of cutting, splicing etc.....
Justin
Turbo84Voyager is offline
Flights | Credit Cards | Bad Credit Mortgages | Mortgage Calculator | Credit Cards
Page generated in 0.44041 seconds with 13 queries
