01-31-2007, 12:09 AM
My Ride: '89 plymouth voyager
What do you think goes on with your current camshaft? It actually takes it a step further, overlapping the exhaust and intake opening so that the pressurized intake can "shove" the exhaust out. This is in addition to leaving the valve open during the pistons rising phase. It works very well with turbochargers. If you want it open further during the rising phase you have a few options, grind a new cam, advance your current cam, or go DOHC and then you can tune the intake cam alone.
I dunno what book you were reading, but in the stone ages cams had to shut at BDC because the engines weren't spinning fast enough to have any kind of inertia to the air charge to help force it into the cylinder.
Maybe you were thinking of an engine that relied on the boost pressure for most of the compression, basically using the engine block as a combustion pot and something to transfer the energy into a reciprocating mass. The rest of the engine work (induction and compression basically) would be done by a huge compressor like a turbine engine kinda. That would be a fun experiment.
