Old 07-16-2007, 11:05 PM   #1
engine turns, no start...
My Ride: '86 Daytona Turbo Z
I have just recently bought an 86 daytona turbo z. It has been sitting for a while so i have done all of the routine checks to make sure that it will run: putting oil into each cylinder, hand crank, new battery, etc. Now the engine turns over fine no excessive noise, sounds like a dream, but it just won't start. What could it be?
Tom86Dayt is offline
Old 07-17-2007, 12:21 AM   #2
Location: a box under the stairs in the corner of the basement of the house half a block down the street from jerry's bait shop...you know the place!
check for codes, fuel pressure, spark, and timing, then get back to us.
macncheese is offline
Old 07-29-2007, 08:05 PM   #3
Okay, fuel pressure ok, timing ok, new ignition system, spark, new fuel pump, new filter, turns, but still no start. battery gauge goes down when trying to start and fuel guage says that their is no fuel in the tank. What could be the problem.
Old 07-30-2007, 06:01 AM   #4
My Ride: 92 Iroc R/T Red
Engine: TIII
how much oil did you put in the cylinders and did you clear it out before tring to start it? could it have fouled the plugs?
Tim
charger R/T is offline
Old 07-30-2007, 07:05 PM   #5
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (7)
so you have no fuel, could be bad HEP
xtrempickup is offline
Old 08-04-2007, 01:31 AM   #6
well, if you have fuel pressure, spark, and timing, check your firing order. I think plenty of people have done it backwards, at least that's what I tell myself!!! Barring that, I agree with xtrempickup and you should try to rule out the HEP.
Old 08-04-2007, 10:56 AM   #7
My Ride: TIII R/T
Feedback: (7)
spray some starter fuild in and crank it, if it fires, you got no fuel coming in and its eitehr bad hep, clogged fuel filter , could even be bad distributor, mine ate the hep and took me a while to figure it out after repalcing the hep and it eating it once more before i replaced the whole thing
Old 08-10-2007, 01:52 PM   #8
Images: 3
i have a 85 daytona and the hall effect pickup just decided to crap out no warning. cheap fix
JONYMOPAR is offline
Old 01-30-2008, 12:56 PM   #9
Re: engine turns, no start...
My Ride: 1991 Dodge shadow
Dont know if this will help but replace the alternator
gizmo719 is offline
Old 01-31-2008, 05:51 PM   #10
why?
91lebaronvert is offline
Old 01-31-2008, 05:59 PM   #11
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
Originally Posted by 91lebaronvert View Post
why?
rofl...
anyways...how much oil did you use. I would take out the plugs and clean or replace them. Then crank it over without the plugs in for a little bit, and see if you can smell gas in the cylinders. Also, add some fresh gas to the tank, you could just have old gas in there.
Stupid questions, but this car DID run when it was parked, correct?
kermit is offline
Old 02-01-2008, 08:48 AM   #12
Mine would kick over and the battery gage would stay at 0 it would turn once or twice then die it was my alternator
gizmo719 is offline
Old 02-02-2008, 08:42 PM   #13
My Ride: 83 Dodge Rampage
Isn't this thread supposed to have something to do with superchargers? Not trying to be a jerk, just works out that way sometimes.
dragonslayer is offline
Loans | Car Insurance | Mortgages | Destin, Florida | Loans
Page generated in 0.38220 seconds with 13 queries
