03-27-2011, 12:57 PM
#15
Re: Supercharged With Nitrous!
Super Pope
your little blower is making tons of heat, so even a little 50 HP shot will no doubt give you a lot more than 50 HP. You can with the bottle setup your fueling. Setup with a hobbs switch to have nitrous go on at 3 PSI. Then you can make your fuel jets bigger to give more fuel for both boost and nitrous. When your not running the bottle, you can add in a fuel jet that is smaller just to add more fuel for just boost. Then you get away from boost power valves in the carb. Then ANY 500 CFM carb works, like the Carter on a 383. It'll take a little tuning to get the right jets for both, but you'll be able to run a $20 carb then if you already have the nitrous setup.
setting up nitrous off boost is nice because your setup just like a throttle control and it'll work off boost. A power valve carb would be cheaper out right. But if you have a nitrous setup there is no reason not to use a cheap carb for the CFM and the nitrous for fuel instead.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
89 CSX 187
05 PT GT
93 Cummins
