01-28-2005, 05:10 PM
Hey, Questions about DC Supercharger kit:
My Ride: 1985 Shelby Charger
Engine: 2.2 T2/A568
Ok here's the scoop. My brother (DC Turismo) just purchases an NOS DC Supercharger kit and we have a few questions about the eventual install.
Is this kit a bolt on deal?
Are there any modifications needed to make it work?
The kit we are getting, is NOS and everything that came with it, is there.
Reason I ask, I talked to a Chrysler tech today (a good friend of my family) and he said that you have to perform electrical modifications, along with mods to the fuel system to use a Supercharger kit. We do not plan on running more boost that what it does in its stock form. It is getting installed only for its uniqueness, not to drag race or anything.
Any help is appreciated.
01-28-2005, 08:49 PM
My Ride: 85 TRiz, 89 CSX #414
Engine: 2.2 NA, 2.2 TIV
Also, does the kit work with the A/C or will I need to pull that when I go to install this beast?
01-28-2005, 10:35 PM
My Ride: 1986 Omni GLH N/A
Engine: 2.2 H/O supercharged
Its pretty much a bolt on deal. There was no electrical work needed for my car except for the sencer. You might have alittle work but not much if you put a carb with manual choke from an elec choke.
You will have to pull the air conditioning unless you don't mind installing a manual rack for you car, this way you will make an extra spot on your pully for 1 item. You will loose some weight off your car, and you'll gain a tiny bit more horse power!
I removed my power steering and installed a manual rack not in find that little more power, I wanted to keep my A/C!
I must say my friend HotRodDodge did most of the work on the car. But I did help a great deal and he has shown me alot.
03-29-2005, 02:57 PM
My Ride: 83 charger 2.2
Induct: S/C
1/4: 15.830
i don't know what carb came with these blower kits but the supercharger that i have is one of the first ones made for these cars around 1982??? or so it is bigger than the newer blowers ...
mine is 88ci
the others are around 66ci
the carb on my car is a DGV-5A 32/36 Weber
it bolts right on to the blower with out an adapter plate
i'm not sure what the others use but i think they are supposed to be the same as the holley 5220 carb but i'm not positive
03-29-2005, 07:24 PM
I believe mine is the same there SC2.2... I know it's dgv, and i'm pretty sure it's the 32/36 model. I'll have to pull out the boxes to verify that though.
You mentioned you had AC on your car, correct?
04-03-2005, 10:52 PM
Induct: S/C
1/4: 15.830
here's a pic i got off of e bay of the whole kit
won't work sorry
04-04-2005, 09:28 PM
I got the pic.: (Notice the carb in the top left corner)
04-10-2005, 12:19 AM
#13
Induct: S/C
1/4: 15.830
Originally Posted by 1fastsleeper
hay, does anybody have a web page for DC?
e-bay
04-11-2005, 10:26 AM
#14
Yeah, DC no longer exists. If anything, it's now Mopar Performance, but most of this old stuff of ours is NS1
04-14-2005, 07:35 PM
#15
My Ride: 1980 Fiat X-1/9
Engine: Chrysler 2.2 turbo
In case you needed them, I've scanned all the instructions and placed them on the net
http://www.pnw-sdac.org/HowTo/BMBlower/BMBlower.htm
Hope this helps,
Stefan
